Martin, many thanks once again!
Qatar - Boeing 777 only have power point in Business Class, however on Airbus A340-600 does have on all seats.
Hmm... Decisions decisions...
so go to something like Expedia punch in your dates and it will show you the planes that runs on that route.
cross check with seat guru and you get an idea of what scenario you are in.
yeah, i think i'll whack on a second hand highflow and stock afm/pump/injectors etc and sell at 230rwkw as a "legal" car.
thinking of selling in at some point... maybe...
Track it!
I'm holding onto my 33 til she dies I think. Nothing comes close for value-performance factor. I also theorise that, like the R32, one day there will be hardly any on the road (decent ones, anyway) and they will be a bit more special than they are now lol.
^______________^ myyyeeesssss
:laugh:
Guess I did alright selling mine for ~$24k
Sold mine without rego or RWC too
How did you justify selling it at that price?
Or you sold it when the market was still allowing you to fetch a high price?
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
