balls in your mouth^
how much boost you pushing?
stock atm. 10psi creeping to 12 with the exhaust.
Fix Xbox red ring of death using overheat trick to reflow the solder...celebration bitches.
Lift up Xbox to put it back in the cabinet, it chews up the COD game disc...FML
Didnt pre-heat oven :domokun::P
Farkin, I thought I had a lot of spare time. This gearbox has always been slangily referred to as a Holden crash box because it has no synchros, thus you match the revs to select gears or they crunch:
http://cgi.ebay.com....E:X:AAQ:AU:1123
So I get a message from some douche:
Dear statusengineering,
My apologies for being pedantic, but, "Gears CLASH, Cars Crash" Cheers.
- *hourglasswoman*
To which I reply with two links to Google searches, one revealing "crash" as the popular term, and the other showing "clash" with no matches, recommending "crash" instead. And he writes:
Hola,
Pleased you took the time to investigate.
Don't rely on Google's search algorithm to find truth. I know most incorrectly use "crash", http://oxforddiction...n/crash?q=crash , instead of "clash", http://oxforddiction...n/clash?q=clash , sorry, just an old tradesman.
Cheers.
- *hourglasswoman*
So I really shouldn't waste my breath, but anyway:
Dear *hourglasswoman*,
I'm a marketer, I rely on popular consensus and Google's search algorithms to sell my client's product, not the "truth" according to a market minority. Unless you plan on buying two of these a month to sustain their sales in absence of their customers who refer to it as a crash box, kindly f**k off.
- statusengineering
Alex, mid size battery, maybe 100cca off my fading memory.
Best to go to Autobarn and look at their chart for battery size assuming everything is stock in terms of electrics
    • So either way it is gearbox out and look what is wrong?  I know about the input shaft bearing. Even before swap/new clutch the it sounded exactly like this: So is that inout shaft bearing or the other was installed backwards?  And can some please tell me the part number for that input shaft bearing? The gearbox is small box from R34 N/A and number is FS5W71C. Thank you
    • I am yet to see anyone ever regret a quaife or helical. ...other than drifting/skidpan duties. I kind of want to upgrade my factory helical with a Quaife (but really it's not ultimately that different, and is a MASSIVE UNDERTAKING), that's how good the hype is about them, that I want to try them 'just to see'
    • D2 and Ksport are essentially the same thing and basically just generic Taiwanese manufacture. Better than ChinaBay crap, but... not top shelf. Öhlins have got to be some of the best dampers around, so likely to be a good option. It's going to get to the point though where I suggest you buy from Oz. We have at least 2x excellent options here. If I were you though, I'd be talking to KW about doing something for the R33. There's bugger all difference between that and the 32. In GTR land, anyway.
    • KW only offers a set for the R32 GTR. Popular options are D2 racing, Ksport or Öhlins. I have a D2 Racing coilover set, though I don't know for sure which one.
    • Well, the good news is you have more than one very good option for new coilovers in and around your country. Worth the drive over to KW to talk about GTR stuff.
