Rossi is past it. Hayden is killing him on the other Ducati. Get around Casey
Who is proving that it wasn't just Demosedici magic responsible for his success a couple years ago! Though I swear that bike outperformed everything else on the straights. In other news, stay up there Lorenzo, Yamaha FTW :wub:
t'was a $35 bet
the gay thing is I was gonna put some money on stoner and my mate is like nah his had bike trouble all weekend! fffffuuuuuuuuuuu
motor racing is so hard to bet on these days - take f1 - different winner every race so far
How low did you went before you chickened out?
i was sitting on the empty line and it was towards the E just a little - but i might wait till i get nismo cluster in before i let it drop that low again lol
Mmmm Nismo cluster. White or black face?
ive had my guage ridiculously low, just above the empty line, then booted it and it dropped right down to its resting position when off. i got scared haha. no fuel light though, it used to work however because ive seen it on although it must be blown now
black :P
white is too.. i dunno out of place for me!
also i have some defi cr black gauges still in their boxes sitting around and they will kind of match
black :P
Hmm... had white in my 1st 33 gtr, looked awesome both day and night.
Get white and swap the defis to white to match?
ha. i've had the car cut out when i turned a corner. im that cheap lol. always got fuel light, never flashed at me though. did go missing for a few weeks, but came back in the end
Surprised you still stuck by yours after all these years with fuel light not working...
Haha car has had bigger things to fix over the years. Never get below 1/4 anyway so not a biggie. Will be slowly replacing all the interior globes now.
touche :P
on topic: i've seen my fuel light far too often this year... damn cheap day keeps changing, and i keep driving too much in between. at least it works. other night i forgot my wallet at mates (was on fuel light as i got there), and drove home thinking i'd fill up next day... little did i know i had forgotten le wallet. so a very nervous trip to work and his place the next day couldn't fill up without teh monies. every light worried car will just cut off LOL living life on the edge. fuel light is great... until you don't remember how much kms you've driven AFTER it's been on....
p.s. may the fourth be with everyone :rolleyes:
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
    • Wouldn’t touch par if they gave it to me. You need to ask how much power you’re looking to make and then add about 50% to it because that’s what you’ll end up making  The factory box says no more at about 350kw or so, the upgraded synchro boxes won’t handle much over 500kw for long and at that point you’re looking at an auto or dog engagement manual,  once you’ve gone dog engagement you may as well go sequential, they cost a little bit more but it’s worth it  also while you’re at it you should upgrade the transfer case with 10 friction plates
