shoulda bought my rims bru.
moh should buy my rims the attention you'll get from biatch's might even get ya knob wet!
Didn't want too many ladies crowding around lol
Nah sizes a bit too hardcore for my soft coilovers / fondness for traction :(
Rims arriving Friday or Monday shiiiiiieetttt
same ones from the start?
Chinese...
HAHAHAHA
not as shit as these
mmmm i have a chub..
your f**ked if you believe the kranzes are shit, those Volks look like factory evo 7 enkei's LOL
You overtook me on the fwy yeah? The bike had the blue parkers
Ahhh thought that was you. Yer slow Skyline in the right lane of the freeway :P
Now people can recognise me...not sure if good or bad lol.
Tsk tsk Patty going slow in the right hand lane
Also lol at Pat leaving 5 mins earlier but him stopping behind me at the Springvale Rd exit on the eastern Freeway :P
Dad is getting old, crashed his car. I think he had a minor heart attack or something mum told me his chest was hurting last night.
Stubborn prick still went to work instead of doc's
What a way to start the day
Lol everything is slow to a motorbike. I had to go 120 to keep up.
Haha went through brunswick st for a kebab :P
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
