On another note, ever since I swapped in my standard airbox I'd lost 50-60km per tank of fuel and felt a little down on power. Swapped my pod back in and it's all sweet again. It was tuned with the pod on, but I thought pod vs airbox was supposed to make SFA difference besides sound. Also, Ric is running more power with the standard airbox...you done any mods to the airbox Ric?
Interesting mr birds, I haven't done back to back test between pod and stock air box myself, but was told the same by sfa of difference.
What kind of filter in your stock air box by any chance?
Makes my blood boil those kids should be smacked around severely and the parents as respect starts at home & school
I look at the government schools around my area the kids are all oxygen theives I just know my tax will be paying for there sorry existence when I was at school all sir/mrs stand up when principal came into the room even just basic uniform policy that was enforced is good foundations
Much work to fit the GTR bov? I'm running 16psi and it doesn't always happen, only when the throttle plate slams shut on a fast gear change.
crossover pipe bolts on perfectly but the return pipe is a larger diameter than gtst. the gtr return hose ID is almost the same as the gtst return hose OD. i mcguyver'd it by slipping the gtst hose inside the gtr one and cable ties but would not reccommend cos it makes a horrible honking vibration on partial boost
Cheers Basti, will give it a shot.
P.S. An online charity was set up to support elderly woman and it looks like she'll be getting 100k from it...bit ridiculous but she definitely deserves something after that.
Nah man, bog stock. I remember we took off the snorkel and the lid on the dyno and it made negligible difference. Never had a pod so can't compare.
That sucks though, I'd love a bit more power and better economy lol
This is what happens when parents don't smack their kids. Disgraceful.
http://www.youtube.com/watch?v=bJ9n8JQJy2c
lucky you can't really see kids faces (only one shortly) because they would get knocked the f**k out if people saw them
I really want to right now myself
Dad is getting old, crashed his car. I think he had a minor heart attack or something mum told me his chest was hurting last night.
Stubborn prick still went to work instead of doc's
What a way to start the day
no shit. my dad calls me at 7 last night and sez he's gonna be late coming home from work and to tell some dude that he was expecting to visit that he'll take a raincheck. cool cool. so i head out to play some indoor. check my phone after (11pm) and find like 20 billion missed calls from mum. apparently, he had fin work at 4, gone to the docs and was ambo'd to the hospital. they admitted him and held him there for 6hrs then sent him home. first thing he did when he got home was to fill up a glass with scotch. by the time i get home he's passed out drunk on the couch.
for added context, he's had a major heart attack last year.
our dad's should hang out
Anyone know the boost limits of the standard R33 GTS-T bov? Starting to get compressor surge at high boost.
had mine up at 2 bar with no fails (although that could have contributed to the motor failing lol)
    • The spray cans were in the "Kiln" room whilst I was preping the parts,  so probably around 2 hours to get them warmed up, the kiln room has 3 small ovens running at 100°c, 3 medium sized ovens running 100°c, and the large one I used running at 80°c, the room itself was about 28°c, I also spent a bit of time taping up the parts in the room as well, and by the time I was done I would assume that the parts were around that 28°c As for power, I expect a couple of Killerwasps up high would be achievable with the current mods, I'm still running the MZR 2.0 intake and throttle body, and there is a slight mismatch with the 2.0 intake (smaller) and 2.5 intake ports (larger) on the head, this intake is matched and specifically designed to fix this issue with the ports mismatch, the throttle body is also a couple of mm larger, OEM is 65mm, the Bosch is 68mm In the end it will look "prettier" than the molded plastic thing that is the OEM MZR 2.0 intake As for the LSD, it's the OEM Torsen which works fine for what I use the car for, plus, basically no maintenance apart from the occasional oil change
    • I was at Tunehouse in Marrickville (great team over there really know their VR's) , and I spotted this Very clean R35.
    • Mate , I have the same issue right now with the exhaust noise , if you can tell me what your local guy did , I'll talk to my guys and see if they can do the same. Power is good but it just too loud when put it down.
    • The other trick I've found with wrinkle black is to put the can in hot water for a bit to warm the paint up, and to pre-heat whatever you're painting. It'll be interesting to see if you pick up any power with the intake, following with interest. Got a proper lsd for this?
    • Plazmaman 76mm Pro Series, done. Data to back it up, I posted up somewhere here a few years back
