Yeh chadstone autobarn 1:45. Probably won't though. Might go straight to bolte
Lol chadstone at peak hour on Saturday? Good luck finding a spot to Pre meet haha
Who going to the Pre-meet? Sau wasteland, we ride together, we die together something something. Sr20's premium before race wars
Yeh that and a 1:45 meet for a 3pm meet at bolte?
Aaron, you dropping in to see the white whale on the dyno afterwards? Don't think I will make the Bolte.
yeh i will be.
turbo needs to come out :( oil fitting leak i think. very minor..
but yeh you can make me the heat shield then.. free sunday?
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
