f**k some of these JDMST kids(fanboys) are sooks. lol 'oh lets hand in all the footage to the cops this that' yeh like your cars not gonna get keyed lol..
fk everyone was doing something illegal by parking there without a permit in the first place lol
Bs parking without permits!? Fkn hard knts! Lol :P
Dw Dezz I'm pumped for tax to already got my paperwork ready just need group cert.
My work is so gay havent had a pay slip since April...Although might be a good thing deffs not one of my better years! lol
Edited by alr33x
An employer is obligated to give you payslips. Just sayin
.txt file will do the job though lol
Lol, please don't send it to me in a .txt file, Y u no have excel?
Apparently the JDMST meet was shit, everybody started to try and one up each other. Lots of people hit the limiter upon exit and some retard tried drifting and smashed his car.
Also it was finished by like 4pm. Bunch of princesses in Melbourne; don't like cold, don't like rain
Glad I had work and missed out on this one. Anybody here actually go?
I did, but I left before it all started as I had other plans
I do have it I just don't know what you want in it or how you want it set out etc
..I'm not an accountant/in IT Toby
No need to make it pretty or in any sort of layout, Just enter your list of expenses and amounts in the columns.
This is just so if there is any adjustments or recalculations to your list, I can do it in excel in a few seconds.
Looking good Pat :thumbsup:
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
