Got my group certificate yesterday come on tax man!
Tony what happens if don't declare interest earnings?
The ATO will know
need group cert x 3 and i just KNOW one company is going to be IMPOSSIBLE to get it from :/
If their doing their job properly it should show up on the ATO Prefill
Tony / Pat
Did you too leave after the meeting point for the VIC Import Cruise?
Yeah left after the meet point to go eat
Spewin was worth asking.. Fkrs so gunna pay tax on it?
Unfortunately yeah. Bank interest isn't something you can get away with cos you usually declare your tfn to your bank, and if you don't they are required to withhold from your interest payments at top marginal rate
I know someone who didn't declare interest from a bank account.
They got a warning letter from the ATO and there wasn't that much interest to declare either..
Ah ok, yeah, weather was shit, but we still went.
Yeah just came down to have a look as had other things to do.
Wasn't the best organisation, alot of the guys I talked to had nfi what was going on because the details said the cruise was going to leave at 1p.m sharp, so a few guys thought because no one is going anywhere and it's past 1p.m that the cruise was off.
Yeah, the organisers hung around a bit just so they could wait for the people who came late.
The cruise needed maps to hand out.
But well sorted it out.
    • So for the wide band is a Bosch 4.9 correct for the Link G4+ along with a Can bus? Just get the Link gear or is generic ok too? Eg here: LINK LINK DIGITAL WIDEBAND CAN MODULE WITH BOSCH 4.9 SENSOR : KYP Performance House
    • Bit difficult to follow. Have a look below and see what the standard R32 layout was like. Note there was a restrictor in place immediately before "turbocharged pressure control solenoid" that, if removed, magically got you 1 bar boost.
    • I might be way off the mark here.. there must be a T junction under the manifold. That takes manifold pressure through a check valve prior to the T, one side splits out to this bleed off orifice, the other straight to the wastegate actuators.
    • Carrying out some engine due diligence before my first drive in a 260RS that has been in storage for 10+ years, and found two lines that are susposed to be plumbed into the boost control solenoid. One of the lines (the wastegate boost supply line) to actuate the gates, had a bolt in one end blocking it. The other line (main boost signal line) from the very rear of the intake manifold (RB26DETT) and runs up to the boost controller had this pill in the end of it as seen in photos. Other than the obvious (T28 Ceramic turbos might well be cooked)  Can anyone shed any light on if there is any validity at all with this mod, bleeding a constant fixed rate of manifold boost pressure off through this 3mm hole?  Is it deliberate?  Was this a 90s Jap mod done to RB26's? Or has someone just fitted this without any idea of what happens to ceramic T28s if they are not gate controlled?
