Dear Leigh,
Thank you for your support of SAU Victoria.
My records indicate that your membership will expire on 7/18/2012. To renew your membership and receive SAU VIC Member’s-Only forum access, CAMS affiliation, exclusive discounts, attend Members-Only events and other great benefits, please follow the simple steps below.
The Annual Renewal Fee for 12months of SAU VIC membership is $50AU and can be made by bank deposit, cheque or money order.
Haha. It hurts to think that to get my exterior looking like that it will cost more than that car for sale :/
Gee tee arghh time!
Should I buy le genuine type R floor mats for $250-300? very hard to find
Struggling for money yet buys $300 floor mats lol. C'mon brah, I don't even look at my floor mats!
Discounts at garage cafe?!?! this is news to me i've been there a few times and noticed no discount :(
Just got finalised as of today :)
Let's just say I ran into some money. Hehehehe... :)
Dealing is bad mmmkay :P
http://www.skylinesa...__fromsearch__1
$15k for s15's these days? Imports getting cheap now...
LOL! Wut?!
Ashneel's has (at the moment) a S15... Guy goes through cars like no tomorrow.
R33 GTR wheels look decent on any other JDM car except a R33 GTR :laugh:
S15's sure hold their value.
Fireblade is doing it for me.
Need to work out if the 1098 style headlights are on the 600/750cc models...
doubt it. just get the 1000...
Just put good tyres on Rim (see that?); wider will only look better; too wide can be a negative thing for handling.
Scored a bike stand off a mate and went to work on chain/sprockets/wheel today. Used a whole can of degreaser and many paper towels. Sparkling fresh
Gonna hit it with Belring chain wax tomorrow; apparently sticks like shit to a shovel. Hopefully never have a grimy rear or chain fling again.
lol stock is 140 can probably fit 160 but doubt it'll look any fatter/better...
mmm sprocket/chain look new
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
