lol, I'm slowly learning about bikes through Wasteland.
You're not alone either!
I think I want a chopper myself after seeing so many in Berlin yesterday and today.
not a fan of bikers that do that/lane splitting etc
you're just asking for it
No need to justify it, you do what you can to stay alive on a bike.
That guy is a little overboard, but back in the day... I don't know how I am still here.
Back in the day? I don't know how your currently here. I'm suprised I havnt set your house on fire yet lol
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
