For real? That's Fkn lame who carries screw drivers!?
lol I carry
a socket set
a ratchet spanner set
gas soldering iron/cutting tool
cross bar
set of screwdrivers
lol
im sure they'll have one, but yeh.
Sif not have emergency tool kit in car. You've owned a skyline before, crazy not to have duct tape, zip ties and tools in the car at all times haha
Bloody reliable Lexus drivers. Haha
I do remember my old mans BMW has an emergency toolkit in the boot from factory. Them nifty Germans
Lol matlab
Only lulz when it's not kicking your ass and you don't know why xD.
OT: With my jack in the boot I've got a little tool set which has screw driver or two and a spanner (along with the hooked bar for jack etc) lols. Thought it was standard :P
Also some electrical tape lying around, think I dropped the roll when I was wiring up HU or something... Handy for ghetto spec reasons like attaching my e-tag, since mine didn't come with the sticky bracket and I keep forgetting to go down and get one :/
Yeh it's a Lexus not an import
It has a emergency tool kit with gloves and hand wash! Haha but no thanks Lexus encore service ftw!
Also did it at home she just said it's at my risk
Edited by alr33x
lol I carry
a socket set
cross bar
set of screwdrivers
With all those tools you could have changed your own engine mounts...
I hate you and your orange car. :P
    • New CAS just turned up from NZ Wiring. Looks like a nice bit of gear.  So, yeah. Triggered, bro. Realised I may as well do the cam belt while mucking about with it so will order one of them.
