Yeh I'm considering 6 or 7.. Hopefully this guy buys my car
VII.9 :yes:
The VII is a bit unloved, as the body styling is plain when compared to the VI and VIII.
VII are cheap, why would you bother with a VI with flogged bushes and gearbox.
Anthony, I've just noticed you changed wing caps to GTR one, it was on my list when I had one never gotten around to buying it.
Now, there's a pair of these on eBay and I'm watching it... My mum thinks I'm crazy.
VII.9 :yes:
Fair point. Apparently the VII have weaker rods though, although I prefer the VII To the other girly ones. Not gonna do much if I get one though so come at me weak rods
the TME still goes for like 18-20k though..
cant justify spending that much on car that was built in 98/99..
no doubt TME is the best out of the lot, but f**k, i already have a 98.. i would like something a little newer.
ahah yeah i bought them from nur33 when he parted out his r33, still have the nismo ones here though, they are faded but hard to find anywhere now which makes me want to use them again lol
it has carbon wing blade also since there was some paint fade on the standard one and also got the patch where there was like 20cent peice size of paint flaked resprayed - as soon as i give it a wash and manage to get it out of my driveway again ill throw up some more pics of where its at - done a fair bit to it as of late.
TME fastest, BUT hardest to deal with on a daily basis unless your going to track it.
7 best value for money, re age/comfort.
8 would/could be what I'm looking for.
yeh im considering just putting cash aside for a little while and getting into an 8MR . that would be good.
    • LOL, all of the CAI like Craig I just need to put a hole saw through my bumper Done and dusted, the car runs, which is nice, I'll take it for a spin when the weather clears up Just need to put the bumper back on for good
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
