was good.
weather, cars, no issues(while I was there)
saw a supercharged 350z that was totalled the day before.
suprised at scott in the wagon pretty much smashing everyone else in his class lol
no idea.. was a yellow track edition.
guy came to pick it up and was still pretty devo..
looked like his daily too with the vic number plates and stock wheels. thing was completely totalled though the only thing not damaged was the passanger door and the roof - the car wouldnt even sit straight.. was such a waste!
Expendables 2 good shit but few fails
1. No Jackie Chan
2. JCVD not on the good side
3. Master badie not being the one and only Bolo Yeung
In other news, not bad weather. Pointless since you know by the time you get home you'll be too dead to go for a ride
nice.. goes to show you can still do some good times with a whale
what car was the 1:52?
motor mag did a 1:53 with a ford f6.. faster than what they did with evo 10 around PI which i find hard to believe
edit: better post some proof before I get flamed /fordsareshit:
https://docs.google....ZQNnlHS1E#gid=0
1. No Jackie Chan
Jackie chan never kills people in his movies. Wouldn't be a good fit for him haha
1. No Jackie Chan
If I go solo, I'm doin a song with Bolo
A big Chinese nigga, screamin "Kuniva yo yo"
Seeing it tomorrow night, pumped
why? freezing?
- VLINGO - it doesn't work and you can not turn it off unless you root the phone.
- freezing - more and more often
- touch screen - not working in some areas which read false touches
- kies software - soooooooooooooooooooooooooooooooooooooooo shit and crashes
- battery life now 1/2 day
and the main prob...
- the button... the only real button is now broken and registers a double tap when you press it once... this turns VLINGO on and the phone (EVEN WHEN VLINGO SWITCHED OFF AND THE PHONE IS ON SILENT) will loudly annouce:
"WHAT WOULD YOU LIKE TO DO?"
1. No Jackie Chan
It's very entertaining, agreed missing Chan but has a LOT of others in it. LOLed when chuck norris shows up..
Phillip Island it quite a fast track though
Woah thanks for the link! That's awesome
I was coincedently looking through all my old motor mags last weekend for track times done at Winton!
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
    • Ok, disregard my “rate them” comment, sorry for my unrealistic input
