+1 at 25 yr old mid life crisis.
I'm 24 and already thinking wtf is my future and what am I doing now.
Read a good article about how gen y is very career progression driven and lifestyle driven. Much different to gen x. Gen y is comfortable in leaving their position to pursue their dreams whereas the previous generations did not.
yeh sounds about right lol life is a trade off though
Big $$$ = no life
Big social life = low $$$
Generally speaking, 100k is the pain barrier once you cross that your personal life suffers that's what I've found with my colleagues/mates etc
lol too true, 100k seems to be the point where you're expected to stress your ass off...6 day weeks, getting home from work then straight into dinner and straight into bed.
I'll be fked if I'm gonna waste my own life to create an excessively comfortable future for my kids to spend all the money/assets I saved up for them lol.
Electrician brahs
Umad ?
Electrician brahs
Umad ?
Thought I was the only one satisfied with my job here!
Can't see myself leaving any time soon, plenty of opportunities to move up and sweet work/life balance
Come at me crisisbrahs
You are still in the honeymoon period. Get some years under your belt greenhorn :P
Hey everyone...this guy's a phony!
Right about the nurses and pay. They are handy to have around if you injure yourself though. The last one I was with was a bit scary...wanted to put me unconscious using my carotid arteries or some shit.
well, speak about scary nurses...
my ex, pretended to be pregnant. (swindled me of some abortion monehs)
pretended she had a blood problem, and wouldn't live past 2013. (hm, right.)
pretended she had a fainting problem.
and i believed her because she is a trained nurse. bloody blackmailing bitch.
Edited by xALmoN
asians..
i had a philo missus like that pretended she was pregnant. i lol'd everyone else thought she was a dick head. she found another boyfriend and like magic she 'miscarriages' lol
asians..
lol
she likes to play in that sort of drama. for her, any attention is good.
i will not forgive her though, for becoming 65kg from 50kg. =x
refused to exercise because of her "blood problem"
Edited by xALmoN
haha ye hence why im about to quit IT and open a business in the hospitality area :merli:
I sell restaurant equipment.. jus sayin.
also, pro tip: try and get into an existing eatery, easily save 30-70k
Nismoid Bugers
Customer "do you sell cheese burgers?"
Ash - "Thread closed. Believe it or not, but since Nosmoid Burgers started more than 7 years ago, this topic has been discussed before.
Please use the search function in future. It may be found here: *Points to Menu*
While we understand that it can be frustrating to have your thread closed - Please consider that other members may feel it to be disrespectful and selfish of you to post a simple question, without using the search feature to review the wealth of information provided by said members over the years.
If you still feel that this action is unjust, then please PM me and we can discuss it further."
you're only out for a few secs
Nice! What's the plan or can't reveal much at this stage?
As for tradies I rkn they are in a massive pay bubble cannot see long term sustainability of the wages, more so commercial sites
I'm 23 and thinking just that.... finishing uni last year with no job!
We should just all go travel around the world while we're at it!
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
    • A couple of notes about the TCM. Firstly, it is integrated into the valve body. If you need to replace the TCM for any reason you are following the procedure above The seppos say these fail all the time. I haven't seen or heard of one on here or locally, but that doesn't mean it can't happen. Finally, Ecutek are now offering tuning for the 7 speed TCM. It is basically like ECU tuning in that you have to buy a license for the computer, and then known parameters can be reset. This is all very new and at the moment they are focussing on more aggressive gear holding in sports or sports+ mode, 2 gear launches for drag racing etc. It doesn't seem to affect shift speed like you can on some transmissions. Importantly for me, by having controllable shift points you can now raise the shift point as well as the ECU rev limit, together allowing it to rev a little higher when that is useful. In manual mode, my car shifts up automatically regardless of what I do which is good (because I don't have to worry about it) but bad (because I can't choose to rev a little higher when convenient).  TCMs can only be tuned from late 2016 onwards, and mine is apparently not one of those although the car build date was August 2016 (presumably a batch of ADM cars were done together, so this will probably be the situation for most ADM cars). No idea about JDM cars, and I'm looking into importing a later model valve body I can swap in. This is the top of my TCM A couple of numbers but no part number. Amayama can't find my specific car but it does say the following for Asia-RHD (interestingly, all out of stock....): So it looks like programable TCM are probably post September 2018 for "Asia RHD". When I read my part number out from Ecutek it was 31705-75X6D which did not match Amayama for my build date (Aug-2016)
