1am.. Rear left 1 month old BC coilover knocking like crazy.... Sounds like whole coilover is going to fall out of car..
Here is the good part..
Half way between shepparton and melbourne..
Awesome night..
Awesome night..
came loose?
came loose?
the way it was sounding is louder than any knock i had ever heard.
got up early this morning and went over the the whole coilover - tightened everything, was all good, then i was adjusting the damper and noticed the bolt underneath it moved.. i found a spanner i could turn it with and problem fixed!
/once again love my bc er's
more flights booked, Bangkok and Singapore booked.
and yes went the marina sands.
I'm driving down to Lynbrook this weekend
Should be good. Nice drive, nice views of Trees. Should be a good trip!
Lol. To Scott's or to your in laws.
I don't know which is worse, emptying pockets for Scott or visiting in laws.
Good luck either way
Anthony
Expecting to see your car at the Show n Shine!
lol how clean does it need to be?!
might need to try find someone to do a really deep cut on it first..
but id like to come down man :D
Lol I usually go down once a weekend to visit the in laws.
Though might pay Scotty a visit to make me a 3inch 180degree bend for one of my intercooler pipes.
Also need to do his Tax stuff
Edited by blah_blah
Isn't your job detailing cars? You should be able to do your car easy!
Doesn't need to be clean at all. Only clean ones from wastelands might be Aaron and Adam
Everyone else might be rocking up with dirty cars :P
Speak for yourself. I've already had two final inspection days this year :P
It needs to be stupidly clean.
Just saying.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
