Bird's, depending on how long you want to wait (and if you can ignore no warranty) buy from the states, usually even with shipping it's cheaper than here
I got my 8' Rockford Fosgate sub for like $75 cheaper than anywhere here shipped from States... Just check eGay
Good idea but I did have a look online and landed would still be around $220 vs $238 in JB - might as well pay the extra and get warranty + not wait. Shame it's not like my Kayano shoes, which were $170 delivered and have only just hit Rebel Sport for $240 lol.
On the side, I'm amazed at how small amps are getting these days. Some of the Cadence micro amps, you could hide them anywhere in your car.
I got my audio stuff from jb on one of their 30% off car audio sales. Ceebs'd waiting too long for any good second hand deals to pop up so was like might as well, seemed decent value on sale.
Speaking of, after chucking in rears/sub & amp quite long ago, still haven't gotten around to installing the fronts in -___-
Edited by kaitoukid
There is a special way to prep and store them, 24hrs isn't long enough for the full benefits ;)
But that said, they will still taste awesome :D
darlek voice TAKE ME TO YOUR LEADER /dalek voice
I cannot recreate the fall off the bone as soon as you look at them of the originals.
Alpine Type X ;)
Nice sub the Type X
Im running a JL audio w6v2 with 1200wrms
Toby, I transferred my renewal payment last month, havent heard back. Show and Shine, next weekend and my sauvic card says im expired :(
In the mail Pat dont stress
Dan to the rescue haha!
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
    • Wouldn’t touch par if they gave it to me. You need to ask how much power you’re looking to make and then add about 50% to it because that’s what you’ll end up making  The factory box says no more at about 350kw or so, the upgraded synchro boxes won’t handle much over 500kw for long and at that point you’re looking at an auto or dog engagement manual,  once you’ve gone dog engagement you may as well go sequential, they cost a little bit more but it’s worth it  also while you’re at it you should upgrade the transfer case with 10 friction plates
