Trust me brah I went through same shit hence sellin 33 with no roady and even the Lexus was hard to get rwc as it was for a sale they just rape ya
Good luck though maybe you got a better place than me?
I don't understand getting to a medical clinic at opening time, having an appointment and still waiting half an hour for it :/
Least the suckers give you free wifi to kill the time...
You sick again?
Hate doctors, even though you booked for an appointment first thing and you're still waiting, what the f**k do doctor do? Touching himself/herself?
Probably old news. But there are a few 86 fans on here:
http://theage.drive.com.au/motor-news/factory-turbo-for-brz-20121023-282ju.html
Not going to put my faith in the sources of an article that claims a 6 second 0-100 for the 86 :/
There will be a faster version eventually though, I don't doubt that.
http://theage.drive....1023-282ju.html
My friend has one on order and he said he would kick himself if a turbo one comes out soon after buying his BRZ. I'll make sure he sees this article.
I loled at that too, they're only about 2 seconds off.
    • Not sure the US can import anything other than the C34 Stagea's, but if you can and you need to to tow, DO NOT under any circumstances get an M35 Stagea. If it is just as a family car and your country/state allows it, absolutely and definitely get an M35 (3.5L if possible as it is effectively a 350Z) over a C34.
    • Punch your VIN (nm35-xxxxxx) into Amayama.com You can see everything there quite easily.
    • Thanks for that, I'll check it all out. I can always do the brakes last anyway if its a problem.  The 16's are super cool, if they do fit I'll cruise around with them for a bit.
    • Well, that's kinda the point. The calipers might interfere with the inside of the barrels 16" rims are only about 14" inside the barrels, which is ~350mm, and 334mm rotors only leave about 8mm outboard for the caliper before you get to 350, And.... that;s not gunna be enough. If the rims have a larger ID than that, you might sneak it in. I'd be putting a measuring stick inside the wheel and eyeballing the extra required for the caliper outboard of the rotor before committing to bolting it all on.
    • OK, so again it has been a bit of a break but it was around researching what had been done since I didn't have access to Neil's records and not everything is obvious without pulling stuff apart. Happily the guy who assembled the engine had kept reasonable records, so we now know the final spec is: Bottom end: Standard block and crank Ross 86.5mm forgies, 9:1 compression Spool forged rods Standard main bolts Oil pump Spool billet gears in standard housing Aeroflow extended and baffled sump Head Freshly rebuilt standard head with new 80lb valve springs Mild porting/port match Head oil feed restrictor VCT disabled Tighe 805C reground cams (255 duration, 8.93 lift)  Adjustable cam gears on inlet/exhaust Standard head bolts, gasket not confirmed but assumed MLS External 555cc Nismo injectors Z32 AFM Bosch 023 Intank fuel pump Garret 2871 (factory housings and manifold) Hypertune FFP plenum with standard throttle   Time to book in a trip to Unigroup
