Get finance dude, it'll be like $200-300 interest by the time you pay it off.
8k and that's a huge bargain. Beautiful colour too.
Hell I'll lend you the cash...and only charge you one, one and a half points tops.
How come you went to Mohsens ?
Nah legitimately the tip... lol it was for work purposes
Birds go click on the link Nick posted a couple pages back.. dude's ebay ad looks like a 13 year old girl's myspace page
Negz, done a few front guards and kept the lining. Tony's one, jonoes two.. And a few others from the BMW forums aswell. And I got my linig back in too, just lost the passenger side so I have to source a new/used one
ah not bad, i cut mine up as they scrubbed. Soft suspension for aussie roads dont like any offset lol
I think so, he said the only reason it's all passed is because its extremely neat and very well hidden ie gate and big turbo.
But for guard lining? Man it's such a waste of time, and one lining is $70
If you can wait 10 days for shipping you can get it for $50 from japan or $20 From UAE through amayama, 63843-65F00 is the part #
More so on ours as there's wires that run along the top rail and apparently "if the tyre pops and shreds the steel lining can rip through those wires"
I'm sorry but WTF...
so a bit of plastic that flys off if you go past 200km/h is going to protect anything if a tyre pops.
as tony would say
this rustles my jimmys
I lost one of mine coming out of the sweeper at winton and the other on the main straight at PI..
not like the attache too well in the first place, never realized it was a RWC thing tho..oh well.
I lost mine on my old car also and that passed the RWC without. I've noticed that mechanics are very inconsistent with these things.
Still more carrying on about Blown GS i see :D
Not at all surprising when a LS3 (6.2ltr) with nothing more than cams/tune/exhaust will put down 330rwkw N/A - that shit be crazy :D
Friend of mines blown LS1 makes 370rwkw and runs mid 10s, blower sits on about 7psi and it's a stock LS1 with 80,000kms done now with the blower (160,000 total). Gotta laugh at that really - RB26's would be on borrowed time in such conditions.
But i'd still take a 2.6 R33 GTR any day of the week. :merli:
Good work Aaron!
Yeah haha my right undertray and guard liner ripped off down the Sandown straight two weeks ago.
Never to be seen again...oh well...
Thanks, but can't need to have in done within 7 days so he doesn't have to do a full Roady again
as tony would say
Not even, the plastic is that thin that of it does pop it would probably go through it anyway Lol
Aaron looks like your mate in the M3 seems to be pretty popular, looks like he'll take out the prize
Also will be driving my bro's Evo for the next week. Forgot how naice it is to drive
Which evo is it? Care to take me for a spin so I know what I'm getting into?
Yeh, people love his m3, and I think most of his mates have shared the link
Evo 8 MR
Yeah can take you for a spin if you want.
I'll have the car for the next 3 weeks or so, so can do whenever
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
