fuuark, this heat! was at my mate's lowering my fronts a bit more... dat solar beam
also left my iphone on the passenger's seat... got the temperature warning and couldn't use it until it cooled down... whoops. xD.
    • New CAS just turned up from NZ Wiring. Looks like a nice bit of gear.  So, yeah. Triggered, bro. Realised I may as well do the cam belt while mucking about with it so will order one of them.
