I'm assuming you havent moved out of home yet, Tony? :P
Actually yes I have :P
Bike parts delivered while at work - now waiting at PO til Saturday, noooooooooo
This is why I do all my deliveries to work
cause I got no utilities in my name, all the connection fees are adding up. that + bond + essential appliances + rent. $5000 excercise :(
however I'm super happy about the deal I it through internode for broadband. saving heaps on my interwebz and mobile
had planned on upgrading the pulsars rear suspension, but doubt that's gonna happen before Feb now
http://www.skylinesaustralia.com/forums/topic/412762-bcnr33-gtr-v-spec-n1-for-sale/page__pid__6603732#entry6603732
fuuuuuckkkk..
called go pro US said it will be shipped on the 13th, and take 3-10 days to be received by me.. hopefully 3 days rather than ten lol
if you bought it, you wouldnt be modifying it...
yet people still do. and i cannot fathom why.
I remember there was a R34 Nur in some feature article. and it included a mods list... i still dun geddit
people are stupid.
Yeah, totally!
And the GTR's with N1 engines don't take much modify.
A tune, cam gears and exhaust and you would be getting a very good power figure for a street car.
Stick to Nismo upgrades, like Exhaust / Suspension / Wheels (to keep it more legit to Nissan) it'd be a sweet car.
Just a mild tune to get it's potential out.
And yeah, you'd only take it to a tune who knows what they are doing.
Something like that? I'd probably send the ecu off to nismo to be simply updated
    • Bummer...yeah i "need" something to "ease" up the work and for my driving it would be enough.    Iam counting the tune "without" turbo. I do not mean "cheap" like something from Temu around 200 USD, "Cheap" is something around 1000 USD?
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
