Ahahahahahaha that's hilarious. The fkd up thing is, I was thinking yesterday during that one...imagine if Tony's missus ends up doing one of these...closeenough.jpg
Cool chick, her friends were all pretty nice too...couldn't believe they were all doctors/surgeons and shit.
Yeah haha shes pretty reserved and of the quiet sort. Marry one of her friends and you will never have to work.
Youll be seeing her again at my wedding lol
Ill be going to her wedding in about two weeks, drop by and do a surprise performance brah
Car full of chicks videoing as I ride alongside. Not sure if mirin or mocking
Either way umad Lee?
Birds I'm down if Lee/Dez lend me their 6 owe owe
Lol, did you dance for them?
I'm too wrecked after coming back from DECA to do spur
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
    • Wouldn’t touch par if they gave it to me. You need to ask how much power you’re looking to make and then add about 50% to it because that’s what you’ll end up making  The factory box says no more at about 350kw or so, the upgraded synchro boxes won’t handle much over 500kw for long and at that point you’re looking at an auto or dog engagement manual,  once you’ve gone dog engagement you may as well go sequential, they cost a little bit more but it’s worth it  also while you’re at it you should upgrade the transfer case with 10 friction plates
