Dez where you get your tatts done?
Anyone know of a good place close by?
i get mine at beautiful body art in narre warren by Daniel clark his insane his specialty is portraits n shiz but his awesome at everything
Mint GTR, would consider if it wasn't spending 18k on a nearly 20 year old car. Can never justify that!
Thanks for the eggs Pat :)
We all should've gone, i only thought of it after you left lol
Leigh will tell you how epic our night was!!! I met a bisexual lawyer chick into reggae lol.
Especially if there's lack of fruits in the car for this much.
haha thank Aaron for sharing the eggs around :P
Indeed twas' an epic night, highlight song would have to be in the end with you and John.. dunno what you guys did but seriously sounded like xfactor or something lol clearly done the karaoke plenty of times :P
Highlight moment was the chubby short girl asking if you even lift. hahaha
Edited by UNR33L
f**k u both for not inviting.
