f*k i'm getting better at parking close to poles aye. I have to park next to a pole. And when I do, if i drive straight, mirror will just scrape the pole. Haha. Too many careless kids and people who slam doors.
I park next to a pole nearly every time. Only had one instance where I wasn't paying enough attention and the wheel arches on the Cube stick out a fair way from the body. Lucky I had the flares.
Mine were genuine too..
And birds it does no negative harm to have heat range 7's
Not harm, but takes longer for the spark plugs to reach optimal running temperature...when you're driving a daily on short trips it makes a difference. Always go as hot as you can without overheating - just like injectors, going as small as you can without running too much duty cycle.
Essentially, I could park our straight piped, externally gated S15 track car outside Knox police station...that short, fat asshole can write a Tom Clancy novel of defects for it...and then proceed to shove the whole notebook up his own ass using his tears as lubricant.
Cars have been defected on Trader Plates. So yeah, you kinda couldn't :P
I ran 7's on my SR20. Wasn't the greatest idea for a car being moved short distances occasionally. Would foul a set beyond use in 1000km's.
i was happy to sit on the limiter on a 40c day at DECA with a trent tune and never managed to get the light on....
jus sayin ;)
Btw I see you may have found 'da 1' e7 pending a check over ;)
:ninja: :ninja: :ninja:
Noice.
Edited by kaitoukid
If his name isn't Sven or Hans, you're being ripped off.
haha probably is I've just never asked :P
They are apparently well audi / vw / BMW
Hmm, still not sure man. I go to VolksHome in Thomastown because it's close to me
holy jeebize id love one but i dont think i could handle a bear haha
Nah those are big males, our female is much smaller
Dog or bear?
Nick would say Dog but its clearly a bear/beast id love to have this bad boy guarding the GTR but the fact that there bigger then me worries me
Yeah dog, although they do have a really strange smell about them that isn't dog at all
i've got a cat. feed, and ignore.
I prefer cats, I wasn't a big fan of dogs until we got Mechka though. She is the best with who know her
That's why I recommend 6s, particularly if you have a conservative/rich tune. Stock engines run 5s okay...no reason anything this side of 300rwkw can't deal with 6s for daily duties with a thrashing here and there.
Noice.
reading evolutionoz forums eh?
yeah, everything set to go as long as the compression holds up and there is no rust / structural damage
Fair point. I had to run em on the 200, I found at 270 with a four banger, 6 was just too warm
Ooo00000ooo got a link u care to pm me with?
jus sayin ;)
Every car is different :)
Just going from a PFC to a PFC-Pro with identical tune, my knock went up by 15 - wasn't a problem with the tune, just the way the ECU was interpreting the signal, so it would hummmm along at 35 and it was totally fine (where previous it'd never go above 20).
His knock sensor could be picking up a little more noise than yours did. Either way 65 knock isn't great, but it's still not bad. Anything over 35-70 usually just means there is 1-2 cells that need attention. Misfiring will also cause the knock sensor to go nuts as well, same as hitting limiters etc.
Odi - wideband won't show you much either as by the time it's leaned off to a point that you'll notice, you've already done the damage (no-one stares @ a gauge when fully up it). Much the same as oil pressure dropping when @ 7000rpm, buy the time you notice/light comes on, the motor is f**ked anyway unless you are setting the ECU up to shut the car down in such a situation via a trigger/value/aux input, which a PFC doesn't have.
I'd suggest having the fuel pressure checked, possible the walbro is faltering now and again, I had one give issues like that 6-7 years ago. However with the misfire could just be a case of a loom/grounding issue. Even voltage supply, so not the coilpacks themselves either. Could also be the CAS playing up intermittently, they have a habit of doing that when they are letting go (you can get another 6-12 months out of them sometimes before they die and the car just wont turn on).
Nissan electricals are a headache :(
you know it :thumbsup:
haha exciting stuff. same as aaron... pm me if links available if you will hehe :P
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
    • Do you have some data like fuel pressure? It's really hard to say if you're still fighting a fuel system issue at this point. Could be something weird like the FPCM dipping out.
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
