oh my bad didn't read that properly, well you'll see my brother at Goodlife! drives a 33gtst
Matt was just trolling around all over the place
Edited by UNR33L
You'll see me and Birds down there then :P
No he won't, we're Genesis fool.
Ahahaha. Too bad, could've learned from you 'masters' ;p
On the issue I was talking at before, looks like I'll probs get my order cancelled and refunded... had a quick read of the site's ToC's (unless they were just updated haha... but doubtful) - and it more or less covers them in cases like this.
So I guess the answer is it depends on the site/company's ToC... basically I think most will have ToC's that state your 'purchase' is rather an 'offer to purchase' until confirmed (and may also have a separate clause for pricing errors) - and they are within rights to not sell it to you (I believe after they have sold it to you, it's too late unless they have some other clause).
Mmmhm. Sadly probably no $9 suits for me hahah.
Went for a ride out the track?
Yep sure did, almost threw up by the time we got back, not a good idea to not drink anything until 2pm and then go 180kmh around a track on a hot day!
Sure was, too busy lolling @ the R Motorsport GTR in the parking lot.
who you go for a ride with that was that slow?
Someone who couldn't put his foot down in 4th without running out of fuel pressure, mother f**ker :P
If he felt sick after laps with me... Imagine him with you or paul or richo....
So apparently there are cars called the Mitsubishi Lancer Evolution VII and I have heard a rumour that they don't handle very well around corners....
I decided to take it apon myself to do some research and document my findings in a short film that I like to call "Sandown Session one Lap one Turn two, How embarressment!"
I didn't puke, so all was good :)
Okay, so he's at least turning through corner 1 now...just gotta work on corner 2 and so on until he's familiar with the layout :P
LOL as if I was, fixing my hair maybe - nohomo
but yes I was there, were you one of the drunk dudes hugging a dude peeing? lol
I was the guy to your right blowing his nose.
You wouldn't have seen me as you were captivated in your reflection
hahaha fair enough, should of said hi! how'd you go on poker anyway?
Wasn't really sure if it was you so yeah
I wasn't playing, just went there to meet up with my mate who was...I played a few hands with his uncles cash when he went for a piss and finished up, so I went well if you count that lol
The suspensions completely f**ked now. Strut tops have completely torn out and grease is coming out of them :S
Tyre pressure was way too low.
Even John Richo drove it and is it was hard to drive.. Guess I gotta learn it abit better
Me two haha. I am not a good passenger. Went in a 500hp 996 Turbo for instructors lap
Even taking laps slower than my own driving I felt like throwing up.
So no more passenger laps for the rest of the day!
    • Its also worth mentioning that 30 years after it left the factory and god knows how many missed oil changes since, there is every possibility that one or more lifters are ticking because they are sticky/gummed up. To resolve that you need to pull the cams then pull each lifter, disassemble, clean, reassemble, soak in oil and re-install, and they should come up good as new.
    • What air filter are you running? Is it a panel filter in the stock air box, or a pod filter? Is the air filter the type that is oiled?   If you unplug the IACV, what rpm does the engine idle at?
    • Reading through the engine service manual their advice is do a cylinder balance test. Unplug one injector at a time and see if the idle drops a consistent RPM. You can also do this using a Consult cable which is easier. They also call for unplugging the power transistor, then with the engine off and the fuel rail unhooked from the manifold verifying that you have good fuel flow (even injection, no dripping/leaks, etc) when you twist the CAS by hand. Also verify the spark by pulling the spark plugs and allowing the plugs to ground and turning the CAS by hand. I would also start doing the sensor checks and idle valve checks in service manual. Make sure the MAF tests reasonably, the intake air regulator is sane, etc. You may have to get new spark plugs.
    • This sounds very old of me, however since buying the Tiguan shit box, my view on shit boxes have changed.
    • I've looked up the parts number (41011AL501). It's around $700 OEM. Usually our Infiniti G35 here in Canada have interchangeable parts with my Stagea but the parts number are not the same. I have looked around and it seems the JDM 2005 V35 Skyline (which is the same as our G35) has the same caliper but I cannot confirm. And I can't find a repair kit. The inner brake pads drags on the rotor, seems to be rusty piston. Thanks for the info by the way
