don't you hate it when you've lost the rear end (more than once) on your FWD when out on a track, later find out the previous owner hit a gutter a few years ago and knocked one of the rear wheels out.
get it measured up at Tyre Factory when they were doing other work and find one of the wheels to have 6mm toe-in and the other 1mm. then take it to Centreline Suspension (more than reputable from what I've seen/read) and they measure 1mm toe-in on both rear wheels........
grrr
Wait till you go down the exit ramp bro. Scrapes like a mofarkin hustler.
Yeah, it's bad up there. Hadn't scraped on any of cars I now have and had.
Good thing I don't have to park all the way up all the time since xmas is over - easier to get parking closer to work.
Down was OK! But it was like 1AM when movie finished, so I could just crawl down haha.
Worst thing about the hump+speed bumps was the fact it's in a freaking grid... once you're in have to take on like 3 more to get out :(
So.
I'm going to be having an informal(perhaps) interview at a HR company for my internship, ceo said "lets have coffee"
and i'm going in full formal, is that a right decision? tie blazer and all dat.
Gl brah!
grrr
I know it's not your point, but sif not get an allignment before hitting the track anyway?
Yeah, it's a grid up the top... All the way to other end of the rooftop.
I knew the alignment after I got it because it was lowered after RWC. the rear beams are notorious for having random toe-in out of factory (guy I know has 7mm toe more than the other rear wheel on his N15, from factory). and there's not much you can do because of the beam axel other than bend it using a jig (which is why I'm at centreline right now). just wasn't aware it was because someone was doing hand-brakeys and hit a gutter...
34 Degrees now, and possibly up to 37?
I'll be at the G to watch the cricket, fml.
/curry lyf
Hopefully it's a good game but....probably won't be. Too bad Sangakkara isn't playing would have loved to have seen him! Get on Fitch for most runs, think he's at 4.50 or something.
Yeah, never noticed til last night haha.
Yeah, I think I read that in the aus line up, only one guy has played more than 100 ODI's.
Yeah Sanga is a class batsman, sad times. O well, will watch Malinga sling it around lolol
    • So for the wide band is a Bosch 4.9 correct for the Link G4+ along with a Can bus? Just get the Link gear or is generic ok too? Eg here: LINK LINK DIGITAL WIDEBAND CAN MODULE WITH BOSCH 4.9 SENSOR : KYP Performance House
    • Bit difficult to follow. Have a look below and see what the standard R32 layout was like. Note there was a restrictor in place immediately before "turbocharged pressure control solenoid" that, if removed, magically got you 1 bar boost.
    • I might be way off the mark here.. there must be a T junction under the manifold. That takes manifold pressure through a check valve prior to the T, one side splits out to this bleed off orifice, the other straight to the wastegate actuators.
    • Carrying out some engine due diligence before my first drive in a 260RS that has been in storage for 10+ years, and found two lines that are susposed to be plumbed into the boost control solenoid. One of the lines (the wastegate boost supply line) to actuate the gates, had a bolt in one end blocking it. The other line (main boost signal line) from the very rear of the intake manifold (RB26DETT) and runs up to the boost controller had this pill in the end of it as seen in photos. Other than the obvious (T28 Ceramic turbos might well be cooked)  Can anyone shed any light on if there is any validity at all with this mod, bleeding a constant fixed rate of manifold boost pressure off through this 3mm hole?  Is it deliberate?  Was this a 90s Jap mod done to RB26's? Or has someone just fitted this without any idea of what happens to ceramic T28s if they are not gate controlled?
