yeh, but 230 kw is eeeeeeeasily enough to skid a gtst and you can spend the remaining coin on trackdays/tires etc
and you can tell hwp to smoke your pole if they EPA you....
pretty much what I do now, dat feel is pretty good
(nek minit fined for fog lights) LOL
Edited by UNR33L
Might get intercooler, run a smaller pulley and e85 down the track, however then I need injectors and fuel pump as well which is all $ and don't think the change from 370 to 450 odd would be that different.. would get me dat 10 though best someone has got with a tune only is 11.3 down the 1/4 mile with good tyres
Or perhaps it's time I save for a house :(
Edited by UNR33L
I'm thinking a shed, I need to be able to store at least 4 cars, preferably more!
I'm limited by my sloping block, designing a 6x9 with extra height to stack cars with a hoist, so should fit 3 with storage
lol... do you NEED a 10?
370 is stupid power! why risk blowing an engine on a 50k car for extra power that you wont be able to use?
don't you hate it when you've lost the rear end (more than once) on your FWD when out on a track, later find out the previous owner hit a gutter a few years ago and knocked one of the rear wheels out.
get it measured up at Tyre Factory when they were doing other work and find one of the wheels to have 6mm toe-in and the other 1mm. then take it to Centreline Suspension (more than reputable from what I've seen/read) and they measure 1mm toe-in on both rear wheels........
grrr
My Pulsar also had near on 0mm toe in on one side and 6mm toe in on the other side - as you know that is within Nissan spec and the only way to get it better is to bend the rear beam. It almost always has nothing to do with accident damage - that's how they came out of the factory.
I agree it makes the car very unstable particularly with quick changes of direction. Could best describe it as crabwalking. Noticed it at turns 11 & 12 at Sandown more than anywhere else.
Edited by llama_au
One day I NEED that 10! :P
Edited by UNR33L
ETA for BRZ is now April, oh yeah! Nearly time for nervous butterflies.
That's quick! What happened to 12 month wait? Our 18 month wait for 86 has been upgraded to ~6 months too.
So you can be free?
yes.
Polo TDi...I'm impressed. Averaging 3.4L on the freeway. Could get to Sydney on $60.
yeah that would definitely be my car of choice if i were to go down that path, love the golfs are the GTI much worst?
Golf GTI is a great all rounder daily. Great tuning potential too. For the money though, Polo kicks ass. Turbo diesel moves off the line and the 7 speed DSG helps. Would get one if it was a bit better looking, but compared to others in the same market it's probably the best looking.
    • The fab work can be as simple as a couple of silicon hoses and clamps to the factory piping.
    • Just sounds like either way you need to do some fab work to get everything to fit, so why limit yourself at that point? If the GCG high flow option is zero effort in and out swap though I'd probably do that. It's almost certainly lowest risk, lowest cost, etc. The HKS GTIII-RS option that Kapr mentioned is laughably expensive for what it is, they charge the exact same for two turbos on the RB26 so their margins are off the charts on that thing.
    • Intake manifold is not a part of the issue. The turbo bolts to the exhaust manifold. That is easy. But close your eyes and picture the physical situation. That is a T3 flange on the manifold and a T3 flange on the turbo. As long as any new turbo has a T3 flange on the exhaust housing, that exhaust housing will bolt to the exhaust manifold. This places the exhaust housing in the same place as the stock one. But now move your mental attention a little further forward. The location of the compressor housing is set by the length of the turbo's core. The stock turbo had a long core. Let's say that it is..... 100mm long. So that would place the compressor housing 100mm forward of the exhaust housing. But a highflow, might well have a centre core that is shorter. Let's say that it is only 70mm long. Now the compressor housing will be 30mm further back in the engine bay than the stock one. This DOES move the turbo's compressor outlet backwards. It also moves the compressor's inlet backwards. You will very likely have to do some work to both the inlet and outlet piping to make everything connect again. I am not say this to make it out to be a bigger deal than it is. I am just pointing out that "bolt on" is sometimes not quite bolt on. The highflow from GCG that Murray linked above (https://gcg.com.au/turbo-charger-upgrade-skyline-gtst-2iu-xtrgts-s1.html ) uses a core that is the same length as the stock core, and so does not require this extra work. It will look very much like the stock turbo. No-one uses GTR turbos of any flavour (stock, or aftermarket) in a single turbo application on RB20/25. It's not a thing. Yes, people have been putting on GT3076, GTX3076 (and bigger and smaller versions of those) and G30s (of various sizes) onto RB20/25 since forever. But these are not "bolt on". Everything except the 4 bolts to the exhaust manifold change with these. And genuine Garretts are expensive. Non-gen, like Pulsar, etc, are cheaper, variously as good or nearly as good. But still not bolt on. No-one in the right mind would pay for an HKS turbo. Not in this modern day and age. Well, yes, the GCG highflow. You could ask HG what he can do to make the compressor housing sit in the original location. There are surely others doing highflows around the world. And some of the eBay/Temu ones (as reported by Dose) work and don't die. Bit of a lottery though. I would send your turbo to GCG (here in Oz) to be highflowed if you want a trivial no-extra-work option. But seriously, the work required to change inlet and outlet piping is not that hard. That's a boost control problem, not a turbo problem.
    • Thank you all for the replys 🙂 I know that intake would be different but that is one pipe at it is not that hard to get(custom one). I meant mainly bolt to the stock manifold and the turbo elbow. I looked and many sites/forums but they are just "old" with some old HKS turbos from GT-R i guess? What about some Garrets?  Or any other turbo? Is there even a turbo which i can just bolt on? 😄 And yeah i know about that new HKS but that is like 2000k USD without taxes/shipping in here   Iam getting a touch up tune but my "problem" is that on the "not" hot day iam getting peaks around 0,9 bar...and when it was around 15 Celsious i saw peak around 1 bar which is just too much for stock turbo. And of course turbo is old and i like to get some new one for a piece of mind 🙂
    • I'm working on the assumption that our friend Jasmine here is a Russian (or, possibly Ukrainian) spammer/spambot, based purely on the number of such that I have been having to neuter in the last few weeks. IP address for the OP above was in WA. But that could have been via VPN. Posting at quarter to 4 in the morning is a good sign of being from somewhere in Europe. The last Jasmine that I kicked in the cooch was IP addressed in Ukraine. Even that could have been via VPN, and the bitchbot could have been from Russia, Serbia, China or anywhere. Regardless, was a spambot, so I killed it with fire. The fact that our new friend Jasmine here did not respond in any way to my tart query strongly suggests to me that this OP was just the establishment phase of a user able to be activated for spamming in a week, or 3 or 10.
