Bring'em to your wedding yeah!
Your welcome to pickup anybody from my wedding lol
Back home and work tomorrow :(
Got tailored suit to try out at Toby's wedding haha
From Vietnam?
I heard they do allright and are cheap cheap
Maybe ill get one too on my honeymoon
Oh yeah Patty check your facebook PM
From Vietnam?
yeah got 2 made in Vietnam along with tailored shoes.
Need to be dry cleaned as they have been crushed since transport haha
Haven't seen te vid (will when I get home from work) yep, mostly GQ and later GU.
GQ is reasonably cheap depending on engine. TD42 (diesel) and RB30s fetch higher price than TB42 and RD28T (turbo diesel).
After some time on carsales seems that the toyota surf/4runner is the way to go
I found Vietnam had much better quality clothing than Thailand, so I would guess the suits are really good quality?
comes down to what the tailor stocks. I ended up buying super 150 grade wool which is high up in the wool quality game. example; internets says hugo boss suits are 130 grade~
Wise choice, parts are easy to find, if you've got 3ltr, Same engine as 2000-2005 Hilux and Prado, so service parts are easier to come by.
2.4l, think some motor share same belt, filter etc...
Fk going to these places, my tailor flies into Melbourne, takes measurements, goes back to Malaysia and sends the suits back over.
Higher number doesn't always mean better quality, just refers to fineness of the thread. There are plenty of 130 suits that are better quality than super 150, they'll also wear better. If you have a job with a lot of moving around, you don't want to be rocking super 150...feels great and light, but you'll wear it out in no time. I tend to save that grade for special occasion suits, weddings etc.
/suitlinesaustralia
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
