Fk going to these places, my tailor flies into Melbourne, takes measurements, goes back to Malaysia and sends the suits back over.
Higher number doesn't always mean better quality, just refers to fineness of the thread. There are plenty of 130 suits that are better quality than super 150, they'll also wear better. If you have a job with a lot of moving around, you don't want to be rocking super 150...feels great and light, but you'll wear it out in no time. I tend to save that grade for special occasion suits, weddings etc.
/suitlinesaustralia
This guy knows.
Didn't buy suits for daily use so should be fine. Got 2nd pair of trousers too incase of any wear.
Pfft what? As if you like getting dressed up? It would be ok if I didn't have to do it everyday. But fk it's annoying, I look forward to getting home and getting out of these clothes
I like wearing a suit...but I don't have to everyday, so it's a bit more special that way.
Also, have you had a proper tailored suit made up for you Aaron? Cause there's a huge diff in comfort between off the shelf and made to fit.
This guy knows.
2nd pair of trousers always a good idea
I've ripped the pants on almost every suit I've owned :/
Could be right, never really bought a tailored suit, but never really felt like I needed to. Al is right you do get treated differently, even in business shirt And slacks, but I just don't like them. I wear the work vest over the shirt for work just because I hate it that much.
Perhaps my opinion would differ if I had a gym body lol. Dunno..
    • I'm going to slap an old nismo logo sticker on my spare one and sell it to the land of the free for a thousand bucks
    • lol, probably should have read further!
    • Well - they have arrived.  And they are easy on the eye to put it mildly... These only have three bolts - but for a start there is a key that fits with vacuum like precision..  And as you can see by my ruler, the interface is large..   I listened to a podcast on HP Academy about Dan (KiwiCNC) and I'm more than comfortable he knows what he is doing. R35 Bearing assembly should arrive later today so can mock that up for a look. Can't wait to get these on and get some brake pressure logging too. IMG_3860.MP4
    • I would be very confident that they are the same parts (the 2 different SKUs). It seems very clear that you can drop the cam in the 2-way opening, or in the other opening. If you arrange it in the other opening in the same way that you see any other 1-way diff, ie, with the flat of the cam up against the 1° side of the opening, then it would work as a 1-way. It can only spread the ramps when driving forwards - cannot spread the ramps on overrun. It would then appear obvious that if you put the cam into the opening "backwards", that you would get the angled flats of the cam working onto the "points" of the 1° side of the opening, which would give you ramp spread in both loading directions. I do wonder if the forward direction of the 1.5-way config is equivalent to the forward direction of the 2-way, seeing as the cams are flipped and the angled surfaces on those would need to be the same on each side - AND - clearly when installed in either the 2-way or 1-1ay configuration they are not intended to work exactly the same (the ramp angles on the 2-way are 10° different between forward and backward, and the ramp doesn't exist in the 1-way config). 'twere me, I think I would rather actually have a set of rings that offered the 2-way with two different sets of ramp angles, say the 55/45 of the existing design and maybe a 45/37.5 combo for a less aggressive effect), AND another set of rings with a dedicated 1.5-way opening and a dedicated 1-way opening. The 1.5-way opening would actually have the steeper angle on the overdrive side that causes it to be less pushy than the forward drive angle, like you see in many other diffs. But really - if this Nismo thing is thought out properly and all those surfaces work on each other the way that they need to, who am I to argue?
