Hit me up with his details. Caught the tailored bug. $20 for tailored shirts > $80 local generic shirts
Will let you know when he's in town, I don't even have his details...secret squirrel Malay-Indian stuff.
cufflinks are the best
i have so many different ones, more than i have shirts even
Yeah you can get some pretty mint ones dude, but putting them on as you're rushing for work isn't the most ideal situations lol.
Cartel Australia
Breaking News:
Force Performance/Team Pig Garage have just been caught with THREE different stolen skylines in their workshop & arrested by police!!!!
Like · · Share · 22 minutes ago ·
Cartel Australia
Breaking News:
Well that's f**ked
Plan on keeping my falcon for at least 5 years, wonder what 35s will go for by then heh
Speaking of suits got a wedding in march and don't fit in mine anymore (dat dere gym) :( maybe I should go tailored as well..
Work wise I just wear shirt and slacks, dunno why not like I see clients or anything
Also Suits TV show is good isn't it Toby!
Edited by UNR33L
I'll believe it when I see it...they've been saying that for years...it's almost a today tonight story. Got a feeling it'll be a "you jump in the pool first" occasion, sif one company will leave another with the whole large sedan market.
If one car manufacturer closes, the parts suppliers will shut down due to low volumes. These same parts suppliers provide parts to competitors too causing a reaction to other car companies.
This is the reason Toyota supports parts suppliers and its competitors because if they close, it will be big impact on themselves.
I think they'd more likely downsize than shut down completely. In any case, it wouldn't be cause for eradicating your best selling car from the lineup - price may go up because of offshore manufacturing, but that niche would be too hard to ignore. There will always be a large sedan market in Australia, however small it ends up being.
there has been a bit of this going on for a while already. parts suppliers get ready to close doors, car manufacturers cant complete cars without specific part(s), so they throw enough money at it (making a loss) to keep the production line running until they find a new source for the same/similar parts.
Some of the decline of the Aus car market i think is still due to the slow and pain death of the manufacturing industry, not entirely on price and market domination
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
