Thats pretty pricy
I'm paying around 400 for mine with 5 shirts, Tailor in HK
last one was from thailand, quality was shit.
but yeah I went from hating suits to loving them jsut from one tailored job.
when something fits perfect you love wearing it,
oh yeah and cufflinks do rock.
mmm carbon cufflinks
Yeah but you go to HK yourself don't you?
The hot part is...last two girls I hooked up with were lawyers, both pretty cute...there was a third that I didn't get with. Saw a hot lawyer in the paper the other day too. Envy for Ric's job!
Yeh except they really will clean you out lol
Cuff links are a must. Same with shirt bones OMG I hate crap collars
I get emails from some himark tailors about when they are in town from hk
Edited by alr33x
still didn't believe she was a lawyer, she was like 12 :P
what ever happened to her anyway? cut all contact? sifn't leave a re-opening seed
Edited by UNR33L
Probably an air lock, just get it bled if you had a minor service they rprobably didn't bleed the system properly
Sounds the same as mine. Thermo fan doesn't switch on which is why your temp is fine when you're moving but rises when stationary, no airflow.
import monster has your car?
damn i was thinking of buying your whole manual conversion.
Yeah sold my car as a whole to them
Thought of parting it but then id end up like you with just a wreck in my driveway lol
lol Ric looks 12. I believed her because she spoke the lingo and could do the splits. Cut contact after conversation the next day...she tried to friendzone me / make me wait on the side to see how things panned out with her bf, which is silly when she cracked onto me. Nobody puts Birds in the corner...
Yeh they go in cages
    • Jack the back of the car up, pull that wheel off, pull that sensor out, and put a bore scope into the hole to inspect the outer casing, see if anything looks damaged before you pull the whole thing apart.
    • Ergh... So I pulled the speed sensor out again and the tip was shiny so I think it's rubbing the bearing. The bearing contains the magnets for the speed sensor so I think when the first sensor broke it damaged the magnet ring on the bearing.  This is just a Google image, but there is a hole going to the bearing. So when the tip broke off the old sensor I'm guessing it fouled the bearing... As the magnet is only protected by a plastic cover it would be easy to damage it. So I guess I'm doing a bearing again.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
