Jonoe, you work at the carwash in Altona/Yarraville?
Near the westgate entrace right? Saw your car parked on the gravel....
I had a magnetic taxi sign that lit up through 12 volt / cigarette. Think it came from eBay.
Had a yellow mazda6 and friends bought me one, magnetic but used batteries.
A while ago, I think his English name was Darren
real name is Chong Hwa Meng
Story of accident
http://ondscene.my/k...ua-rempuh-tiang
Fucking hell!
I am guessing he couldn't handle it and lost it while turning?
Wasteland move so fast, cbf keeping up.
LOL!
Fkn lol. Relevant to a couple people here who met him / had him over for dinner at their house...
http://www.skylinesaustralia.com/forums/topic/418077-patrick-hamilton-a-warning/
That's so bad.. But why has he never gotten in real trouble for shit like that?
I'm sure someone will stomp his teeth into a gutter for takin a snap of the wrong girl
Well talking about things doesn't really have means for getting into trouble, and what you do O/S is just that...
So ye, not much trouble to get into really.
He already got in trouble, it's only just clicked to me actually. A long time ago I remember him saying that he lost custody over his kid cause the cops found child porn on his computer and he said someone else framed him or used his computer themselves to look it up...starting not to believe that one now.
He also got pulled over roadside for a routine search through his laptop for illegal porn...
Tipping he'll be in jail soon enough. He reminds me of my ex-friend who goes to Asian countries and acts like a complete tool taking advantage of being a westerner over there and thinking he's king shit.
Yeh I guess . What a freak show..
How's the business goin?
haha ye pretty much!
Good, opening will be mid Feb sometime, we should be in there end of Jan to start setting up once fitout is complete etc. Will do a soft launch over a week for family/friends and then go the larger opening week etc. Cant wait to get in there really and start doing it
We got approval for a Facebook page so will have a few offers for people and what not:
https://www.facebook.com/SquiresNunawading
just the horrible inconvenience of a gearbox on his doorstep that he will have to move.... OH NOES
does he wear a bintang singlet?
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
