I know its a few pages back
But how is his surname actually spelt,
Pettet
Pettite
Pettit
Can we get a poll going on ? cause everyones doing it differently. Also has he got a wife? cause i know of a pettit somewhere in southeast. :P
Pettett if I remember correctly from the defect label, I'll look later.
Ive been knox a handful of times in my r34, never had any trouble... yet
I drive past there 5 times a week and have only had trouble once. But it does happen; just a numbers game and the wrong time of day.
my brothers now 340rwkw (on trents hub dyno at least..) car still cant pull on me, dat dere turbo lag vs supercharger
can we quit this faggotry about hub dyno's reading higher please? i'm soooo over it! they are better and more accurate... it's one dude in adelaide that bullshits his figures and happens to have a hub.
trent's dyno is callibrated correctly and runs the appropriate correction mode.
cars on trent's dyno make the same power as on a dyno dynamics in shoot 6 mode
my car was within 10kw of 2 different dyno dynamics rollers
Pettet
Pettite
Pettit
easy...
F A G G O T
easy...
F A G G O T
Hub dynos are better as you eliminate variables in the tuning (tyre pressure & slip at the wheels) makes it possible to repeat runs and have results the same. Good for fine tuning as you don't have unknown variables messing with each run.
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
