hasn't vivian (adrian) turned into such a tosser these days..caravaning around UK learning about local customs..
was much better when he would tell them to sod off then headbutt them.
so true
work wants to pay me monthly now. hooray. credit card here I cometh
How is getting paid monthly a good thing?
its because once upon a time sunkist broke my heart <\3
You guys can make up again this Saturday night
It's not... it's just good for the company as it reduces admin costs
Pretty sure he was being sarcastic, hence the disenchanted hooray at getting a credit card.
Haha so I see, my sarcasm detector wasn't working
must be a great vday.
know the feeling:
but our announced last week.
http://www.zdnet.com...ort-7000010253/
you safe tho?
yeah some people pretty upset here at the moment, ah well
yeah I'm safe
I'm a mechanical engineer.
oh. why you learning SQL for that?
need electrical engineers.
need software engineers :( I'm trying to hire two for my team.
Monthly pay is fine unless your bad with money
this
FKN LOL
this chick at work wants to have more data allowance for her iphone through vodafone...
voda aparently CAN NOT increase the data on the plan to 5gb/month...aparently it's physically impossible
so instead they give her a pocket WIFI modem that has it's own simcard that is on a 4gb/month plan that connects to her phone via bluetooth. the thing is as big as a phone.
I would have fkn RAGED
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
