Guys at Racepace said stay away from Yellow Jackets.
RacePace tuned my car with YJs and said nothing about them lol
Have done back to back dynos on 300rwkw cars with Splitfires and YJs, same graph same power. Admittedly your car is a different ball game, but if I was after something urgently I'd trust in them.
I get stuff from JJ before I even want it
I get it usually before i buy the car...
Wouldn't exactly call it a lemon. It's just the car is old.
I have similar 'experience' with other white 33 GTR...
lol guard rail
do you get a freq cust discount like every 5th tow free?
lol pay out on Grant hour.
lol. he probably purposly f**ks with his car at night just for the tow.
hahahaha I can so see this, guy feeling poor sneaks over and disconnects some cables from grants car.
even worse say he getting his car serviced near where grant goes, purposely fks with grants car so gets paid to go pick his own up.
thinking of the endless possibility...
You having so much problems with your car Grant? Or wasteland taking a piss on ya? lol
just rereading that however, I aways call, rather than putting in order on the site, always seems to come in cheaper that way, so maybe he processes it straight away then.
hmmmm..... will call to order items from now on then!
oh awesome!
should make him pay for all the damage!
Make him pay for your burnt coilpacks.
Glad they actually chased up the guy unlike mine..... did my own investigation and even gave them the link to the sale ad and fb of the guy that stole my car and nothing.... :closedeyes:
Just saw on ch9 news that an Indian was fine $100 for not wearing a helmet while riding his bicycle.
His excuse was that no helmet would fit over his turburn and that he can't remove the turburn as it's against his religion. Case is going to court.
Mum is literally LOL'ing.
He will win. Minority religion runs this country!
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
    • Hi.. Just another problem. So maybe you can help. I(my mechanic) done swap from my RB20DE NEO to RB25DET NEO. Everything is OK but we have a boost cut. Coils/Plugs are ok...AFM is ok. ECU is ok. I have Walbro 255 but it "changed" sound few months ago(you can hear it ouside) you did not hear that when it was new(maybe faulty?) Sooo...what now? What can cause this boost cut? It is even when you standing still...
