Guys at Racepace said stay away from Yellow Jackets.
RacePace tuned my car with YJs and said nothing about them lol
Have done back to back dynos on 300rwkw cars with Splitfires and YJs, same graph same power. Admittedly your car is a different ball game, but if I was after something urgently I'd trust in them.
I get stuff from JJ before I even want it
I get it usually before i buy the car...
Wouldn't exactly call it a lemon. It's just the car is old.
I have similar 'experience' with other white 33 GTR...
lol guard rail
do you get a freq cust discount like every 5th tow free?
lol pay out on Grant hour.
lol. he probably purposly f**ks with his car at night just for the tow.
hahahaha I can so see this, guy feeling poor sneaks over and disconnects some cables from grants car.
even worse say he getting his car serviced near where grant goes, purposely fks with grants car so gets paid to go pick his own up.
thinking of the endless possibility...
You having so much problems with your car Grant? Or wasteland taking a piss on ya? lol
just rereading that however, I aways call, rather than putting in order on the site, always seems to come in cheaper that way, so maybe he processes it straight away then.
hmmmm..... will call to order items from now on then!
oh awesome!
should make him pay for all the damage!
Make him pay for your burnt coilpacks.
Glad they actually chased up the guy unlike mine..... did my own investigation and even gave them the link to the sale ad and fb of the guy that stole my car and nothing.... :closedeyes:
Just saw on ch9 news that an Indian was fine $100 for not wearing a helmet while riding his bicycle.
His excuse was that no helmet would fit over his turburn and that he can't remove the turburn as it's against his religion. Case is going to court.
Mum is literally LOL'ing.
He will win. Minority religion runs this country!
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
