the mona lisa lol
The first thing I want you to do is rip that e brake
The only reason the evos pop on e85, is because tuners like to cram timing in downlow.. The rods can't handle to much low end torque..
Burnzy has said out of all the 7's he has tuned on e85 only one popped, because of something completely different.. Ie waste gate or something
Yeah fair enough, good thing I'm going 8+ and I'll probably get burnzy tune as well. But i thought we were talking about injectors fouling due to e85 not tune pushing out too much torque low down especially during search for power wheh e85 tune
Yeh. That's the main reason they blow if they have injector upgrades..
If not. It's because they are of the retard kind and expect stock injectors to flow enough for r85
Think youll need bigger sprinklers, dont quote me on it though, could be wrong.
He'll be find. Won't be pushing anymore than 250 with an RB20, he could just about get away with S15s for it.
Dat 2.0
he'll probably only use 4 tho
so i dropped my phone at work and didnt realise. find it bent like a f**king banana and crushed.
worker ran it over with the fork and didnt notice.
f**k.
also, sam greco came in yesterday.
actor from fat pizza, swift n shift and underbelly
also seems to f**k people up.
See him every Tuesday..knew he was from those shows but never knew his name... nice bloke
What brand?
I made it to 330rwkw at 92% duty on nismo 555cc
but most people have run out of flow much lower (thinking nismo 555's are just the 740's painted a different coulour)
Cheers
They are SARS injectors. Rated 550cc. Had them flow checked. Came back 570cc reading
Smashed taco's for lunch. Was amazing.
I love the flavouring on Salsas chips :yes:
Monosodium glutamate, also known as sodium glutamate or MSG, is the sodium salt of glutamic acid, one of the most abundant naturally occurring non-essential amino acids.[1] It was classified by the U.S. Food and Drug Administration as generally recognized as safe (GRAS) and by the European Union as a food additive. MSG has the HS code 29224220 and the E number E621.[2] The glutamate of MSG confers the same umami taste of glutamate from other foods, being chemically identical.[3] Industrial food manufacturers market and use MSG as a flavor enhancer because it balances, blends and rounds the total perception of other tastes.[4][5] Trade names of monosodium glutamate include Ac'cent, Aji-No-Moto, and Vetsin.
Not confidence inspiring...
But dat e85...
why wouldnt they upgrade the injectors and pump if going to e85.. trusting 12 year old injectors is obviously not the smartest thing to do.. lol
You misunderstood, this was with upgraded 1000+ injectors and fuel pumps
give it to me immediately
cost moneh
The best part was ignoring the S15 they could have used instead...
The Mona Lisa if you will...
Also re: the e85 evos, I thought he meant that was happening WITH upgraded 1000cc+ injectors and fuel pump.
Yep, not on standard injectors/pump
your an idiot, I'm talking about e85 destroying the insides of the injectors and making them run lean
Everyone knows about the late modelled 6.5 and 7 weak rods
Who cares about Evos anyway, we were talking Skylines and E85. You Evo boys take your 4 cylinder garbage out of here. Only milk and juice should come in 2 litres blah blah get out my country.
    • That is way more science than even I would use. I just eyeball it, not even accounting for the non-verticality of the tape measure when held on the lip and the centre at the same time. +/- 2mm is good enough for the girls I go out with.
    • So, before putting them in I need to understand the stock ride height. This is how I measured it: First, check the diameter of the wheel's centre cap, it was 52mm. Then put a piece of masking tape approximately across the centre and measure 27mm (half) from at least 3 sides to get a reasonable idea of the centre of the wheel cap. Mark that with a horizontal line as one measuring point. Then, directly above the wheel on the guard, put another piece of masking tape in approximately the centre. Use a string line to find out the point on the guard above the centre of the wheel cap and mark that. Then it is simple, just a tape measure to check the distance from centre of the wheel to the centre of the guard. Final results where  LF: 381mm RF: 379mm LR: 401mm RR: 400mm Pretty even considering they are 120,000klm old factory springs, lets call that 380 front and 400 rear.
    • So....knowing that I have a problem with power steering temps on track and another Wakefield day booked in next Friday, I've done the obvious thing They are very reasonably priced at $1650, considering they are a big monotube shock, double height adjustable (don't have to change pre-load to change ride height), one way adjustable damping and standard sized and customisable springs if you want something other than what comes with them. They come with 9kg/mm front and 4.5kg/mm front and I went with that as a starting point because I'll add adjustable sway bars too https://justjap.com/products/bc-racing-coilover-kit-ds-ds-infiniti-q50-v37-14-current#description Unfortunately they didn't come with rear strut tops so I've re-used the factory ones which was a bit of a pain. Also, the adjuster for the rear shock will be an absolute nightmare to get at, and while there are extensions in the kit I can't see any way you can actually attach or use them
    • I also had 2 bulbs blow at once, years ago in the stagea. made for a fun drive home. The issue was the voltage regulator had failed in the alternator and it was giving 15+ volts. Really, I was lucky all that was fried were the headlight bulbs. So, I'd suggest you check the voltage across your battery terminals with the car running and warmed up. Yes, you will need a multimeter to do so, sorry.
    • Good work to think to check that, and thanks for coming back to post up the outcome.
