My skyline is 2ltrs :(
Might give it a miss on the ethanol tune. Will get a pulp tune first so then I will have 2maps to switch between.
that's cute
nah but seriously waiting for yella terra to release their intercooler kit for mine, then add some e85, injectors and fuel pump and run a smaller pulley come at me ~500rwkw all in good time..
Edited by UNR33L
Got a call from manager and their photo showed up whilst ringing. Found that odd as I didn't add any photo?
Turns out Facebook detected their mobile number and my iPhone showed their display pic. Also to add that I don't have them added on fb either.
So that means a long as you have someone's mobile number, you can find their Facebook profile automatically O_o
only if they've got the number displayed on facebook I guess
Edited by UNR33L
What's the craziest engine conversion someone has done in an Evo?
WRC spac tune bro.
There's surely no way around that!
Amateur
you want your helmet or not you roid raging dropkick?
glasses are annoying, wake up, can barely see clock / find your phone, have to take them off at the beach / swimming cant look at womens or see mates / throw balls n shit, have to clean them all the time, can't play footy, can't wear sunnies, look like an idiot at 3d movies, can't see shit on roller coasters with no glasses, fog up in shower or heat, can fall off during sex, annoying to get motorbike helmet on, can't take semen to the face, have to get special wider goggles when I was doing motorcross the list goes on, can't motorboat things
Contact Lenses :)
wat?
Cos train line?
I meant just in general, but I suppose that would have an affect on it too...Personally I don't want the fkin thing anywhere near my house, but if it means some flog will pay me more for it one day, I'll deal with it
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
