Honestly don't understand how you're not a massive fat kent...
On the flip side... Who's up for a wasteland squires loft night, maybe a week night next week? Like Thursday or something...
I'm in for squires. with or without ash spittin on my steak.
Is he giving you mad discounts?
I'm in for checking it out either way. Want me some steak yo.
BTW funkymonkey/shan ... If that's you in dp I swear I may have seen you at some point at my work. And your name is one letter off mine in that ive an extra letter lawls which is what reminded me because u or that guy was like 'hey ur name is nearly same as mine' lols. Or could be some other curry named shan, who knows XD
Edited by kaitoukid
You can take your car overseas to travel and keep your original plates on it. Saw a BM motorbike a while back with German plates. It needs to be all in English characters though so places like Japan do special versions of their plates which replaces the prefecture etc with English initials.
dunno. more f**ks could not be given about discounts as long as we get good steak.
You bros should get some numbers together for Sunday too. I had to lock in a table ASAP so I only got 4. 7:30pm Sunday.
Uhhh... I do remember sayin that to some dude name Ishan I think... can't remember where. Ohhh I remember at IKEA Springroll.
Saw a beemer on the freeway with british plates... eh?
you can pay extra on around the world cruises to take your car. get to country, drive car around, get back on boat, and repeat.
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
