Honestly don't understand how you're not a massive fat kent...
On the flip side... Who's up for a wasteland squires loft night, maybe a week night next week? Like Thursday or something...
I'm in for squires. with or without ash spittin on my steak.
Is he giving you mad discounts?
I'm in for checking it out either way. Want me some steak yo.
BTW funkymonkey/shan ... If that's you in dp I swear I may have seen you at some point at my work. And your name is one letter off mine in that ive an extra letter lawls which is what reminded me because u or that guy was like 'hey ur name is nearly same as mine' lols. Or could be some other curry named shan, who knows XD
Edited by kaitoukid
You can take your car overseas to travel and keep your original plates on it. Saw a BM motorbike a while back with German plates. It needs to be all in English characters though so places like Japan do special versions of their plates which replaces the prefecture etc with English initials.
dunno. more f**ks could not be given about discounts as long as we get good steak.
You bros should get some numbers together for Sunday too. I had to lock in a table ASAP so I only got 4. 7:30pm Sunday.
Uhhh... I do remember sayin that to some dude name Ishan I think... can't remember where. Ohhh I remember at IKEA Springroll.
Saw a beemer on the freeway with british plates... eh?
you can pay extra on around the world cruises to take your car. get to country, drive car around, get back on boat, and repeat.
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
    • I thought the same to start with. But then I thought it was one of those LCAs where the end of the ARB goes through a bushing in the LCA itself, instead of having an end link.
