2 door is good excuse to watch dem struggle in mini-skirts.
and 2 door is harder to escape while car is moving, you know incase they do a runner.
Good thinking
Keep in mind that Leigh's engine came with a factory 335 flywheel kw and the current HSVs have 325 in stock form. If Holden put out a blown V8 it'll be above the FPV power figure cause that's what those two companies do.
In the end what's gonna matter is displacement and power handling potential...if they use LS9, it's a supercharged 6.2L engine > supercharged 5 litre. Coyote is a great engine, but there's nothing particularly trick about it...all supercharged engines respond well to pulley upgrades and tunes.
It would be interesting to see the price though; if they spread across the range or save it for the GTS.
Gee fair whack on your first outlap.
Looked really slippery? Oil spill there previously?
Aaron. We barely half way through. If u come now. Still tonnes of food!<br /><br />And there is no guinnea cops now!!!!<br /><br />Good wine hurr too. <br /><br />We just doing stuff bit by bit.
Lol mad invite!
Come past one night brahz! Take me for a spin uleh
Pretty sure HSV stated it won't be the LS9, and if it were yeah they're awesome but expect to pay 100k+ for the car lol
Also the ford modular engine is complex, much more than the pushrod single cam chevvy 6.2lts, I'm talking n/a vs n/a here 5lt vs 6.2 and 6.4 ftw
The 5.0 L (4951 cc, 302 cid)[12] "Coyote" V8 is the latest evolution of the Modular engine.[13] Ford engineers needed to design a V8, specifically for the Mustang GT, that would compete with the GM 6.2L LS3 used in the new Chevrolet Camaro, and the new Chrysler 6.4L Hemi ESF in the Charger and Challenger.
Edited by UNR33L
ford and holden both have to keep each-other in check with stock power figures, also the supercar scare shit will return if they go nuts.
Ls9 has displacement and that is all and with 1.2L still isn't as efficient uses more fuel and needs more mods to be on par with a 5.0 on same boost levels.
power handling potential? on stock blower 5.0 coyote many people have made 480-510rwkw stock engine zorst pulley intercooler tune e85 intake.
ls9 will need heads cam, zorst intake pulleys e85 larger heat ex-changer(internal plenum cooler and external radiator)
keep in mind here the 5.0 coyote has a 1.9l blower and the ls9 has a 2.3l
imo stupid debate anyway, FKN v8 MATE
@ hamish, does the sous vide in the esky hold 59 degrees for the entire hour? or is there a temperature drop?
I'd normally prefer to sear after i sv though. so i'd be concerned about temp drop when i put in the meat.
my esky drops approx .5 - 1 deg per hour so not really...
you can sear afterwards, works the same, as you are not putting enough cold meat in to drop the temp of all that water.
I have done both ways, however sealing first works better for sous vide as the flavour of the searing penetrates the meat.
even in professional kitchens with propper vaccuum sealers and circulators I seal the meat first
    • Ok guys thank you very much. GCG highflow it is then 🙂
    • forgot to mention that when it does this it does not kill the engine, but I have not kept the pedal down long enough to let it, as I see no reason to beat up on it as its got to be something simple, small and dumb causing this.  And as soon as I let off pedal, the engine returns to its normal super smooth operation and rpms re-stabilize quickly, once below 4k.
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
