Search NPC on these forums, or read the drivetrain sections. Always recommended. Mine is organic and rated to 300rwkw. Softer than the cushion button Exedy I was running before.
orly that all? I heard that the Exedy HD Organic is capable of 350+
Also Hamish I don't think we do!
if you can handle a snappy clutch grab the HHHDBC, it's cheaper and holds a lot more power than the organic...
I treated mine like shit and when I blew the motor and we pulled it out after 12 months it was like new
and are you going to see 350?
Not for a long while, but 300 is easy so I'd like to at least be able to handle a bit more (bit more = thrash it more on lower power ;) )
Don't wanna spend too much, found a company selling Exedy HD Organic for $399 delivered out of the UK!
Yeah? They good are they?
Yeah Co-worker said he could probably get them cheaper through there.
Is this for a gtr? If so I had a Racepace organic in my old r32 gtr I'm sure I was told it was a modified exedy. This was years ago tho! I had 290rwkw handled it very well all round but was ordinary on launches. Most organic single plate clutches won't handle big launches too well on Gtr's other than that they're pretty good for street use.
You mean the standard Exedy HD clutch? No way...those things burn out with 200; be surprised if they even have the clamping pressure for 300. Trust me, the NPC is the softest pedal feel and most daily friendly clutch for 300...cause it's a bigger plate than standard...after that you'll be looking at heavy pedal and button clutches. So many converted from Exedy to NPC.
Yeah standard 32R, will be putting -7s on it eventually though. Am thinking either Organic HD Exedy or this NPC that Birds recommended.
uwot? We put them in a fair few GTRs and they're rated to 350+, I'm sure they start to slip at that point, but I don't think they're gonna have trouble with 200 considering stock power already is 200 :P but I'm definitely looking into NPC now as they're a good $2-300 cheaper for the same, if not better clutch.
You sure you're not talking about the HHHD Exedy? Cause the standard HD organic is supposed to be as god as the cushion button, i.e. SFA power handling, just harder launches than a standard clutch.
I got my exedy from these guys..
http://stores.ebay.com.au/NORTHERN-BRAKE-AND-CLUTCH
were cheapest in melb when I got mine.
I gave them call and they did cheaper than their ebay add as no postage or listing feeds, plus a free exedy hat!
direct from excedy... got mine (HHHDBC) reeeeeeal cheap
would have to assume racepace would have an account with them or could start one at least
who with and how can i get said bargain?
buy mustang profit.
had car for 10 years and the agreed value goes up not down even with no new mods.
oh and to answer question, shannons
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
    • Welcome mate. Any pics? Even with a DE I'd be well happy if I had that as a 1st car.
