Bit hypocritical and self-indulgent this person whinging about the job they "have" to do (cause nobody else can handle that shit, right?). I agree with the premise, that people all over the world are too easily offended, but this sounded like a big "woe is me" tale. Your job is shit, it always will be and nothing you blog about will change it...if you can't handle it, then take a word of your own advice and quit the Internet dumbass. He/she seems to want to blame other people, who had nothing to do with it, for a little girl's rape, because he/she now feels responsible for not being able to answer the call.
Would have been received much better without the "poor me" perspective.
:yes:
Waiting at home patiently for my boost gauge and boost controller.
Door bell rings, runs with joy skipping and hopping to the door to receive a delivery of the AB Wave my mum ordered........
Hahahah my mum orders the same useless shit, I could fill one of our bedrooms with the useless exercise machines we have at home
they really do shoot themsevles in the foot (feet?). they say their product is amazing, and yet they bring out a new different model that is supposed to achieve the same thing.
But lets be honest, these products do get muscles working more than... well watching TV. Just doubt it'll make your abs stripper-spec.
If that's one of those ab wheels... Those things can be killer lol.
Re: gauges and ebc... I just want boost already :(
Edit: @above, I thought RAM only comes out in May? I think they released track list though
Edited by kaitoukid
Ram comes out 21st may, I've got the vinyl pre-ordered and I can't wait!
A track list has been leaked - I believe it's only which artists are performing on each track with them.
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
