White Work XD9 on silver 33GTR work well? Had a little fiddle around on PS before cos I couldn't find any other silver 33 gtr with white xd9's.
My car looks 95% similar to this car. Excuse the front lip as I don't know how to use photoshop.
If you propose too then im convinced tony has started a pact
There was a SAU VIC Committee meeting to discuss the future of SAU VIC wastelands.
Certain members of wastelands were picked to marry and breed. A Noah's Ark if you will
You've all just been inceptioned
My gym in Wantirna has an open day (i.e. bring a friend free) next Tuesday, so if anyone wants a free training session / me to run them through some good basic exercises, I can do that. Probably have to be late arvo though, as I am picking up my beautiful girl from the airport in the evening.
Oh? Dis be in mah hood!
I like. But then again I have white wheels on my car. May be biased. Edited by kaitoukid
What colour does the car have to be for black wheels to NOT work? :P
A-a-ron maybe... Depends on time/locale. Btw do you know how long it takes for all the sau shit to get send out? Mate got his in the nail already, I'm still waiting for mine :P
Dunno probably not late though, opera? Dude you jut got married and you're already old lol
Only going because its a client and its free.
Otherwise I would rather just stay at home and watch the footy!
Yeah Alvin, bought Bel's old car. For me, bronze is a little bit hit and miss on silver. Took a pic in japan of a white 33R with bronze xd9 and looked epic though!
I kept trying to convince Brandon to sell me his LM GT4s but I think that'll never happen lol
Gunmetal XD9s do look nice on silver as well actually, there was a pic of one at Sandown on my
comp but the angle of the pic didnt display the wheels very well. I'll have a tinker on PS again to see what it'll look like.
Was originally quite firm on either TE37SL resprayed black or black LM GT4. But now the more I look at it, seems like
33Rs look better with some dish which both of these wheels tend not to have much of..
    • Stock ECU (or more accurately stock tune) absolutely refuses to go over 10psi and behaves like you have seen. The Nistune is the same if it is the stock tune. If the Nistune chip has been tuned, the resulting tune could be literally anything for any combination of parts. The Nistune just makes the stock ECU Tunable.
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
