I thought I could subconsciously ignore the first 1000 places of pi; turns out I was wrong
3.1415926535 8979323846 2643383279 5028841971 6939937510 5820974944 5923078164 0628620899 8628034825 3421170679 8214808651 3282306647 0938446095 5058223172 5359408128 4811174502 8410270193 8521105559 6446229489 5493038196 4428810975 6659334461 2847564823 3786783165 2712019091 4564856692 3460348610 4543266482 1339360726 0249141273 7245870066 0631558817 4881520920 9628292540 9171536436 7892590360 0113305305 4882046652 1384146951 9415116094 3305727036 5759591953 0921861173 8193261179 3105118548 0744623799 6274956735 1885752724 8912279381 8301194912 9833673362 4406566430 8602139494 6395224737 1907021798 6094370277 0539217176 2931767523 8467481846 7669405132 0005681271 4526356082 7785771342 7577896091 7363717872 1468440901 2249534301 4654958537 1050792279 6892589235 4201995611 2129021960 8640344181 5981362977 4771309960 5187072113 4999999837 2978049951 0597317328 1609631859 5024459455 3469083026 4252230825 3344685035 2619311881 7101000313 7838752886 5875332083 8142061717 7669147303 5982534904 2875546873 1159562863 8823537875 9375195778 1857780532 1712268066 1300192787 6611195909 2164201989
will we have our hoverboards by then ??
and powerlaces
Surely we cant be too many years away from fitted GPS's mandatory for all cars then as soon as you speed automatically fined? :\
I'm sure this will be implemented and the law will not be amended that states a speedo must be accurate to within only 4 km/h yet you can be fined for 3 km/h
I got a few planes I wouldn't mind detailing for $50 - $200
4d7703cb2a8446ed84285f88767f1341-Airbus-
Relax... that plane doens't exist.
looks like a superguppy had sex with an A380!
FYP brah :P
RicRolled!
I can recite pi to 40,000 decimal places. - The last number is Zero
Haha it's seen better days. When I picked it up from final inspection after wet sand. 'twas a mirror
Dude... your car is a 20+ year old nissan with peeling paint, an 2 litre motor and fake LMGT-4's.
It's probably worth about $4000 on a good day
STOP SPENDING MONEY DETAILNG IT!
lol...harsh....but true, be better spent on new paint....I dont bother detailing mine much... :laugh:
plus it sits in my backyard so not much point....occasionally i try a new product on it but thats about as far as i get..
i'm fine with keeping an old car, but stop trying to polish a turd ffs.... just, slam it, get some better offset and be done with it... the car is too far gone to be a show car
Picking up my Frankenstein GTR/GTST Driveshafts and K-Frame today from Pedders, going to be all Whiteline'd and awesome.
Anzac day = Our ancestors fighting for our freedom to take the day off work and reassemble skyline rear ends while drinking beer and eating bbqs :)
yeah, every other day I offer hate... i'll pay that
today it's reality... I dont hate pat's car at all...
hell I even quoted the beaurau of statistics in the lulz thread... you can get more real than that :P
    • Put a fuel pressure gauge on it. Replace the turbos. Probably completely separate issues.
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
