is that all fast is..., all it tells me is my car has 2 doors, and an rb25 and is gunmetal grey..AMAZING!!...
I though it gave a list of how many owners etc...what is the point of it...?
Say you wanted to know the Nissan Part number for the Exhaust Gasket on your exact model of car... Throw in your VIN and you can use this to follow the path down to the individual part number. And then it can link to amayama to order it...
The example VIN they've given for a Nissan looks to be an X-Trail...
http://nissan-europe.epc-data.com/x-trail/t31r/970-qr25de/exhaust_and_cooling/200/20691/?frame_no=Z8NTANT31AS001483
Edit: And when I say "Exact model of car" I mean that my car (R33 GTST with the A-LSD Diff from a GTR VSpec) will show very different part numbers from most other GTST VIN's...
Edit 2: Also, if your car is Gun Metal Grey, but fast comes up as "White"... I'd be quite concerned ;)
its on mountain hwy.
any good bro? some local pho that's decent might be good in these upcoming winter months!
in other news, me earlier today:
due @ 11:55, submitted @ 11:55 LOLO.
its not bad really.. but i'm now a bun bo hue person.
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
