What's been cracking wasteland? Went to deca and had a blast in the wet, never knew how much fun it was spinning all 4 wheels through 1st and 2nd was so much fun.... now to chase power to do it in the dry.
I've heard the loophole that I can say mines a replica of a 1988 model and can get club rego for my 1993 model!
orly?
stripped my RB26.
head looks like its in top shape.
piston #3 is f**ked just above the ring
bores look okay though? wtf?
orly?
stripped my RB26.
The Victorian club permit scheme allows members of car clubs (including motorcycle, trailer/caravan and machinery clubs) that are recognised by VicRoads to make limited use of historic vehicles on the road network.
A club permit can be issued to the following vehicles in the following categories:
  • Veteran vehicles – manufactured before 1 January 1919;
  • Vintage vehicles – manufactured after 31 December 1918 and before 1 January 1931
  • Classic and Historic vehicles - manufactured after 31 December 1930, but more than 25 years before the date of the application for a club permit.
These categories can include trailers and modified vehicles such as street rods. Vehicles which are replicas of vehicles in the above-mentioned categories may also be issued with a club permit.
keep the 20 in there until you can afford the 25/6 box
you will only destroy 20 and have to replace it.
better to be able to sell the RB20 & box as a package or to sell an unbroken box on it's own complete as opposed to small metal fragments
    • Yeah nice idea, you mean to suction it to the gauges? I hadn't thought of that.
    • A few suggestions: Do you have the option of retarding your exhaust cam gear to bring the power band over to the left? VCT would be turned off after you make peak torque, you see the power/torque will decay faster with it left on all the way to the limiter Once VCT is turned off, you'll find the motor will take a bit more timing being ramped in Send its mum, more boost! Of course, depends on your exhaust pressure.
    • Tow a boat... people won't know wtf is going on 🤣
    • I was back on the dyno again yesterday after completely revamping my methanol injection system. I was making 440kw at 19psi. Great, this is more then I was making last summer with my old meth system at that pressure, and I figured it would be smooth sailing up to 30+psi. We continued increasing from there and by 25psi, I had only hit 455kw. Dyno sadly lost utility power at this point and I left. We seemed to be on course to hit the same power wall as last summer (477kw@27psi). This is a built RB25 S1 stroked to a 2.8. Built and ported head with Kelford 272/262 cams. Precision 6466 Turbo. Tuner last year believed the power wall is a mix of RPM limitations (Hydro lifters/Limit set at 7600RPM) and fueling. With my new meth system, we're seeing zero knock now but it still won't go up.  What else can I do at this point? Here's my train of thought.  - It's clear from the dyno graph that I would easily make power to 8500+RPM but I'm limited to 7600RPM. I could risk increasing my limiter, but hydro lifters have me worried. What are my options here besides going NEO head or solid lifter conversion? I'm rocking a 1.05AR turbine on my 6466. Would dropping down to a .84 help shift that power down in anyway? - We're only seeing roughly a 30kw difference at the top end with VCT on or off. Is this normal? I want to confirm VCT is working properly. - Should I look into other cam options?  - Should I just keep increasing boost and see if she wakes up later on? I would expect to hit 600rwkw around 35psi with my 6466.
