an omelette... with eggs?! :rolleyes:
and the EF3 plans? naice.
ef3 is already installed.
benny from benchmark will be remote tuning it soonish.
had to fix the wideband not logging via the ecu (fixed last night, was referencing the wrong data point), and i blew out 1/4 of the head/manifold gasket (replaced that monday morning before work) and the previous owner chopped 10cm out of the lower radiator hose so i had to replace that so the intake pipe would fit on nicely (fixed that tuesday morning before work)
the 2.3 kit parts are all sitting there waiting, just need the cashola to have it built, but im in no rush, with the ef3 instead of the gt30 its so much nicer to drive, even on the stock 2L.
orange juice for extra flavour.
Yes four stud (only need 8 for front) and yes i prefer steel over the aluminium Rays ones that have basically been stripped.
I need 1.25 thread because Nissan
mine were used on the skyline (LMGT2 wheels have retardedly small holes for the nuts)
i assume the evo is the same as the magna which is 1.5 thread iirc, which means they are useless to me. if you want them $20 posted
yeah have read good things about benny on evooz.
i would be leaning towards and ef2 or ef2.5 i think, but if you've got a 2.3 to go on later... sweet as. exciting times.
the 3 isnt what i would call laggy, it makes some positive pressure at 2k (0.1-0.2 bar) and at 3k makes ~1bar.
if i didnt have the 2.3 kit, or a skyline that was making 390kw previously, my pick for a low cost setup would be an evo 9 turbo on E85, or get the GTPumps slightly tickled version with titanium rear wheel if you have a larger budget (same as what lance has (black evo 5 making high 290kw on e85))
I bet after it comes on, it's all smiles :P
Yeah that's what I'm leaning towards tbh. Or perhaps a bbk lite (or maybe even full) / fp green if i'm searching for a bit more... but E9/RS turbo looks like srs contender for the route I take.
i looked at the BBK and FP turbos, but 2300/2500 for a high flow stock turbo, no thanks.
at the moment its only running gate pressure (18psi) so it goes but its got nothing on the skyline in terms of how rapidly it gains speed.
Nothing definate yet, Let me just check if the lady is free for din dins
Hi bubs,
How's your day going?
Would you like to go out for dinner tonight?
I'd love to go try out that Japanese place, Chiba, that my friend works at, and he's working tonight
http://www.chibajapaneserestaurant.com.au/
xx,
Simon
Reply =
Hi Simon,
There is so much going on in my head all the time and so much I don’t and can’t talk to you about. I have been trying to talk to you all week, since you returned from DECA, but I was so overjoyed to see you and spend time with you that I kept procrastinating. We have such a wonderful time together. You are the most amazing person I have ever met…
But there is something wrong with me. I can’t be with you. My heart has been severed in two and part of me is lost. I just keep telling myself that with more time passing and us becoming close, things would get better inside of me, but they haven’t. And it’s killing me. I can’t keep in avertedly hurting you, and me by continuing this. I have so much guilt about it. And so much pain.
Please don’t hate me forever…I wish more than anything, that you could be happy…but I am not the person to do it.
I love you and I’m sorry.
Dat stock spool? :P
Haha... what's the plans with Benny's tune? ~25psi?? Evo's boost monsters.
Reply = Her breaking up with me for some unknown reason... da fuq?
If srs... wtfux :(
Simon brah
That shit is whack and I knew where if was heading from the first line. I wouldn't have even replied to it; breaking up over email...
That last line is a kicker and will provide me with sufficient lulz and/or jimmy rustling for the day.
Consider it a bullet dodged early on, my man.
How long we're you with her for?
EDIT: almost forgot to ask, was she any good in bed? I would expect at least an R = 0.8 correlation for dat dere cray cray.
Dat stock spool? :P
If srs... wtfux :(
Going to leave it at gate pressure for now.
Will go crazy on it once built, don't want any chance of block windows, ain't nobody got time for dat.
I don't intend on using e85 on it at this stage, I only want ~300kw from it.
    • Put a fuel pressure gauge on it. Replace the turbos. Probably completely separate issues.
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
