Bruce Willis; dead at the end of Sixth Sense.
Lotsa movies don't have plot twists. I like them when they randomly happen. But when some f**k tard says there's one, you sit there wondering what it is through the whole movie until it happens. No surprise. Half of a plot twist is that you're not expecting it; the other half is that you're not expecting if.
i dont have that problem. i just like yelling at the screen when people are doing things i disagree with.
I like spoilers if its a movie its gotten widely mediocre to negative reviews and I dont think it'd be worth seeing. eg. Oblivion.
But you gotta go looking for them. googling spoilers is handy.
Oblivion was awesome. It had plot holes but that wasn't the point of it. Posed a lot of philosophically and ethically confronting questions.
Ayo tits, reminds me of that scene in Scary Movie where the black chick get stabbed by everyone in the cinema cause she doesn't shut the f**k up!
Plot twist is fair game in any movie imo, not exactly a new construct.
Although some movies sorta hinge on it I suppose, perhaps like Fight Club.
Oh, was that a spoiler? Too soon? :rolleyes::whistling::P
If you've read a bunch of Palahniuk though you expect that twist everytime cus they're all the exact same Damn construct with different characters in a different setting.
blipshift tshirts they sell one tshirt for 3-4 days.
then sell a new one.
so if you want it you have till 10th June
http://blipshift.com/
Thanks Martin, browsing that site now.
THANKS FOR THE SPOILER WTF BRAH WAS GONNA SEE THAT TONIGHT
Ja Rule still in prison :(
or else he probably would have made a cameo in F&F6.
Why he go prison for?
Strong beta in this thread
Also...they put BLADE in jail
Also...hate people who say "I won't spoil it for you, but there's a twist in the movie." - that is spoiling it, you f**king moron.
this, but with fnf6 most people knew there was another movie coming anyway. Especially with all the moneh they making
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
