$3138.30 for parts and labour to remove, diagnose, replace a 2006 Alfa Romeo GT Selespeed Gearbox...
... Because Alphalpha.
Why did I say "Ok" when asked to Fix and Sell this car for a workmate who had to go to America suddenly... *sigh*
but they are paying for it all yea? so why does it bother you? get them to pay the bill and it gets fixed, they dont pay it, it doesnt get fixed.
All because 2 Teeth broken off the crown wheel in the FWD Diff... And noone wants to touch it...
Man, if it was a skyline, it'd be like $300 for a new diff and it's good to go :P
bitch please, $150 will get you a complete 2nd hand diff in housing.
Probably wont buy new xbox or PS, I have both current gens and never ever use the things lol
probably like 30 hours all up on my xbox and like 4 hours on my PS, guess i use that for blurays sometimes though
I bought GT5 and a G27 combo for like $450 when it came out.. probably used it for like an hour lol
GT5 was shit compared to forza
Edited by UNR33L
Yeah I bought the G27 for like $450 or something before GT5 was released.... I've used it a few times, GT5 is more fun with the wheel, but definitely harder. Drift with it is awesome though :D
I'd sell my G27 in perfect condition for $250, it's been used about half a dozen times... just a little dusty from sitting in the cupboard for ages.
Extent of engine damage if anyone was interested:
http://i1171.photobucket.com/albums/r550/Leroy_Peterson/photo4_zps68459400.jpg
http://i1171.photobucket.com/albums/r550/Leroy_Peterson/photo5_zpsced4539c.jpg
http://i1171.photobucket.com/albums/r550/Leroy_Peterson/photo2_zpsdb2d4023.jpg
http://i1171.photobucket.com/albums/r550/Leroy_Peterson/photo1_zpsef23003d.jpg
http://i1171.photobucket.com/albums/r550/Leroy_Peterson/photo_zpsfa85b4d3.jpg
hooray for engine rebuild and mi-goreng diet time!
Will be nice to sort out issues through and make it better than it was. Seriously, one adjustable cam gear and its set to 0 anyway *Jackie Chan*
Springs might not as been good as originally thought, cause theres not many left in 1 piece lol.
ouch :/
dual valve springs?
    • Given you're running a 2.8 and my 2.5 is not really like for like, I suspect there could be a bit more timing you could give it. What is the kW yield per degree you're putting through it? Here's my E85 map to give you an idea, where it was I could still get another 3~4kW per degree thrown at it.
    • It turns out that Setrab make a fan specifically for the oil cooler which is great and I've installed it with minimal swearing. I removed my 2x 12in push fans from the front of my aircon condenser and wired them into this. My main thermo fans kick on when I use the aircon anyway and would effectively already be working as puller fans through the condensor which is infront of the rad. The push fans (understandably) didn't really do much in the config they were previously in so now they're out. Now we're on to the "Oil fan doesn't really do much either!". Yes I'll duct it next if it does nothing in heavy use which it shouldn't. But hey, the object exists and fits great and is cool. Let me have this. The car is still in the "do my fittings leak oil now? do my wheels actually rub?" phase. I did a spirited drive on them and didn't hear or feel anything. Then I got back home and noticed there were grind marks on the inside of the rims, though I couldn't see where they were touching I got out the grinder and attacked the suspects. Note: I do not know how to use a grinder. Then I realised I had dragged my new rims across my concrete driveway before I did this drive. I didn't think I had damage at that time when I briefly looked...... but remembered this occurred after I did all the angle grinding. The grinding on the wheels in some very specific spots. It's not around the whole rim for example, which lines up with dragging it across concrete more than hitting a suspension component for even 1 full rotation. So everything is currently painted and taped up and I need to test it some more to see if it really IS rubbing, but from inside the car it doesn't feel like it is. In other news I attempted to do a before and after comparison of the heads/cam upgrade thing. Dynos lie, everything is in different measurements. Here is the data from the sandown back straight. Car go faster than before. Vroom vroom.
    • Here's my base ignition. +3 correction to redline when shooting water/meth which is always on. Looking at my old ignition table, I should be able to add 1-2 degree's next time I'm on the dyno.  Let me know your thoughts.
    • Given what I know now - same haha, but this was 12 years ago with second hand 740cc Nismo injectors in my S15 daily, I was too busy hunting elsewhere for the issue to even look at the injectors, running through some cleaner was a happy coincidence haha
    • Not a terrible idea. But if I ever had concerns that my injectors were sufficiently dirty to be causing me a problem, they would be out of the engine and onto the actual injector cleaner/testing bench.
