e85 = annoying
know few people on it and they're always on like empty and complain that they cant drive and cbf getting/driving few km for e85
370rwkw on 98 good enough for me :D
Edited by UNR33L
Interesting. Pics?
Long gone now so no pics, but they are only blind rivet nuts that are secured to the body and then you can make you brackets to fit and screw into them
Pretty easy
Nice!
Year / model / mods?
+1
And please welcome, "DJ Press Play" to the stage!
2002 10th Anniversary v8
so all the optional features as standard (sunrroof, rear reclining seats, air suspension, leather, electric rear shade etc)
Only mods are a set of 18" Rays Sebring ITC wheels, which I'm going to get rid of anyway
Got 130xxx kms but it's the 2nd cleanest one we found, and it's $7k cheaper for not having black leather
e85 = annoying
It's always those that have never run e85 that pay out on it. There are many benefits to it, and the only draw back is your fuel tank was designed too small? Get with the times...
24" with a thin layer of rubber (gettin kinky) are arguably wheels.
VIP wheels would be a hard choice. Its either gangster or something that would compete alongside a hilux with chromies.
Thats a joke, but worked out in your favour.
Plans for wheels?
Few I'm looking at
SSR SP3
Work Schwert SC4
Leon Hardiritt Gral or Bugel
But I haven't really looked into it much yet, need 19s as minimum too
i'm sure he is planning on having wheels dude
LOL
hmmm... I like the gral's the most. bugel's looked a bit sparse for such a big vehicle.
I lol when people talk about wheels and sound like interior decorators
all about the contrast, had gold volks on my last black Nissan, but decided to go with a unique bronze textured finish this time
im not bagging the guy that said that (he's a nice guy) it just sounds funny.
oldenburgs look baws on majesta
SC2's looked pimp on ashneels chaser, but look weak on the huge-ass majesta
Yeah saw them and thought they looked awesome
It's hard though having toyota offsets, to get the good dish at back you need to run either massive camber or flare rear guards
But either way, I'll look properly once the car comes in first
:rofl:
e85 = annoying
You'd only run e85 on a track car to squeeze the last bit of power the car can make.
Or you end up with what you said... e85 = Annoying
So 3rd Generation S170.
You going 2JZ or 1UZ?
Leon Hardiritt Oldenburg also
Yeah that looks mad!
VIP Car so it needs thick spoke wheels with deep lip.
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
